Old 16-03-06, 02:02 PM   #1
Saracen
Default Rejetted, and WORKS! now running rich in low revs??
Following on from my adventures here, here and here:
I've put everything back togethere, with the new 145 Mikunis and moved the clip up one notch on the needle (so there are now two free notches below it, away from the point).
Fantastically, the bike started. I had to run it on the starter for about 30 secs, but I presume that's because there was no fuel in the carbs? Anyone confirm?
It runs fine now.
But at around 2-4k RPM, the revs don't back off normally when I close the throttle; there's a small delay. I resume this means it's running a bit rich? Everywhere else is fine.
This can;t be the jets can it, since the jets mainly affect the upper revs? Any ideas why this might be? I did readjust the mixture scres 2.5 turns from where it just seats. I've also made sure the idle ias around 1300 RPM.
Any tips (Northwind?)
Old 16-03-06, 02:06 PM   #2
Scoobs
Are all cables and linkages free and lubed?
Old 16-03-06, 02:08 PM   #3
Saracen
Bit naughty, ut I didn't actually lube anything. But it only happens at low revs, so that shouldn't be the cause. What's recommended for lubing the throttle cables and stuff anyway?
Thanks.
Old 16-03-06, 08:07 PM   #4
NedSVS
Yes it is normal normal to take a few seconds more cranking when the float bowls have been emptied (but perhaps not as much as 30 seconds). Your revs hovering at 2 - 4k is usually an indicator of the air pilot mixture being lean (the increase in main jet size will only have had a very small effect on the low speed running). First I'd try turning the pilot air screws out to 3 1/2 turns out and see if that helps. You may well find you need larger pilot jets with your de-baffled CCC. If you do, you can get them from Allens R&D in Nottingham (01949836733) part number N224.103 follwed by the number of the size you want (17.5 is standard, so you want 20.0 or 22.5). Hope this is of help.
Old 16-03-06, 08:12 PM   #5
I doubt that... 3.5's a lot, I'm running a full system, better filter, and tank spacers and I'm on 2 3/4. He's not changed the induction at all since before the rejet and it ran normally before.
There's a chance you have a problem with the choke cables- did you remove them at the carb end? They can stick there, and the cables can get stuck in teh wrong position at the ends and at the y-splitter (sleeve pulls out of the mounting sometimes.
Old 16-03-06, 08:25 PM   #6
NedSVS
This just shows how much variation there is from exhaust system to system. I beleive you (Northwind) run a BMC RS filter like me, but with my micron/Quill hybrid I am running 22.5 pilots at 2 1/4 turns out. I could get it to run on standard pilots but always had a tiny flat spot just off closed throttle. I don't beleive I have any air leaks (I put everything back to my known stage one induction settings to check this).
Old 16-03-06, 08:58 PM   #7
What I mean is, I doubt it's his problem. Different systems call for differen thtings, you're right- the restrictive headers of the Micron systems fuel better low down while a more open system like mine gives more top end... But he's got a standard system.
Old 16-03-06, 09:21 PM   #8
NedSVS
Not quite true, I'm sure the CCC will have some effect too, not just the headers. I'll be very interested to know the result of this one; so let us know how you get on
Old 16-03-06, 10:58 PM   #9
Stig
Following on from Northwinds point on the choke cable. Mine has been running very rich. So rich that you can smell the stink of petrol coming out of the exhaust.
The choke cable was working fine. I have now stripped the the carbs off again and found that the front choke plunger had seized in the open position. This caused the front cylinder to run rich constantly, regardless of the choke position or indeed the operation of the choke cable itself.
When I finally got the crappy cheese bolt undone on the front plunger and pulled it out, it was actually rusted in position.
Having now sorted this problem the bike runs a lot smoother in the lower rev range.
I do however need to replace the choke cable, but seeing as I never use it anyway, it can wait.
Old 16-03-06, 10:59 PM   #10
Marginal though. Certainly not enough to have this huge impact on the idle circuit. And not when it wasn't an issue before he rejetted. This is something new that's happened as a result of the breakdown and/or rejet, and since everything else he's done is to richen things up, why would he now be dramatically lean at idle?
I bet you 10p
Running lean / rich sauluk SV Talk, Tuning & Tweaking 10 15-05-09 02:06 PM
Running rich AndyBrad SV Talk, Tuning & Tweaking 1 14-09-08 12:41 PM
im sure its running rich John 675 SV Talk, Tuning & Tweaking 11 03-10-07 01:21 PM
running rich? 01 sv650s SV Talk, Tuning & Tweaking 17 10-02-07 10:41 PM
What should Dr Rich / GS Rich / Rich call himself tomorrow? Cronos Idle Banter 29 01-04-05 03:03 PM
