Old 02-04-06, 09:15 PM   #1
BIKER-DENE
Default srad 750 calipers 6 pot
will these fit on a sv650s 200 sy?
thanks
dene
Old 02-04-06, 09:48 PM   #2
Robw#70
No, not without adapter brackets and better with 320mm discs so different wheel needed, might as well wait and fit the whole front end
Old 02-04-06, 09:50 PM   #3
BIKER-DENE
so what calipers fit right on ?
better ones?
Old 02-04-06, 10:20 PM   #4
TSM
The Sick Man
TSM's Avatar
None
Old 02-04-06, 11:50 PM   #5
BIKER-DENE
i thought srad 600 calipers fit right on to the sv??
Old 03-04-06, 12:05 AM   #6
TSM
The Sick Man
TSM's Avatar
Nop, have you seen the distance on the mount points & also the disk position?
Old 03-04-06, 12:09 AM   #7
Nope. without custom mounting work, there's none. Unless it's an SV thou, which can take the 6-pots off a K1 or K2 GSXR thou I think, if you really want to. I've got no idea why you would, mind
And tbh... I reckon that if you're able to do the work yourself, it'd be cheaper to fit a GSXR600 SRAD RWU front end than it would be to get plates made for calipers, as well as far more effective. I would've broken even on the 750 USD front end swap, if I'd not blown the budget on bells and whistles And the 600 bits are cheaper. SV bits are expensive, older GSXR bits less so.
Just smacking huge calipers on a standard SV is a really bad idea IMO, all it'll do is make the fork dive even worse. And by the time you'v upgraded the internals to make use of it, you'll definately have spent more than a front end swap would have cost (again, presuming you can do most of the work yourself, but believe it or not it's far less diffcult than you'd assume)
SRAD 600 discs richwill68 Thames Valley 3 31-05-08 10:24 PM
SRAD discs richwill68 Stuff Wanted 3 31-05-08 09:32 PM
SRAD calipers pad spring yorkie_chris SV Talk, Tuning & Tweaking 8 10-03-08 07:58 PM
SRAD 750 Yokes andyb Stuff Wanted 5 19-10-06 08:17 AM
SRAD Shock? mysteryjimbo SV Talk, Tuning & Tweaking 18 22-02-05 09:57 AM
