Old 10-04-06, 10:52 AM   #1
kciN
Default Water Pump casing, paint flaky-flaky!
Hello,
Just looking at this engine for sale on ebay and noticed the water pump casing paint is starting to flake off.
http://cgi.ebay.co.uk/Suzuki-Sv-650-...QQcmdZViewItem
On my 51 plate curvy I have the same problem, and it bugs me!
Does anyone else have a problem like this on their curvys or indeed pointys!!
If so, can anyone recommend a good paint/spray to use.
This photo is actually from my bike. Not incredibly clear as fairing lowers cover it, but you get the idea
Old 10-04-06, 11:01 AM   #2
Yup, they'll do that. You could spray it, but it'd be a pig of a masking job with the bolts- I've got a couple of spares, going to get them powdercoated I think, but it's not a simple job to fit or remove them either, it's a sidecover-off job.
Old 10-04-06, 11:47 AM   #3
kciN
Originally Posted by northwind
..... it's a sidecover-off job.
Do you literally have to take whole side casing off?
Does it not come of with the bolts that hold it on?
Old 10-04-06, 12:06 PM   #4
Nope, you need to get to the other side for the actual water pump gubbins. Or at least, think you do.
Old 10-04-06, 01:17 PM   #5
svrash
Sure do...........
Thats why
Old 10-04-06, 01:18 PM   #6
chewy22
Mate had same problem see here on my site http://www.chewys-stuff.co.uk/engine...650k2right.jpg
Old 10-04-06, 01:31 PM   #7
kciN
Sure do...........
Thats why
So are you saying, that if I want to remove the pump casing, I'll need to remove whole side casing? (Still confused!)
Are there bolts internally that can only be undone by taking whole side off?
(Will study Haynes Manual when I get home later)
Old 10-04-06, 01:45 PM   #8
Carsick
I think he's saying that there is a gear (pictured) attached to the inside of the water pump housing that you need to remove before you can remove the housing.
To get to this gear you must remove the side casing.
Old 10-04-06, 01:47 PM   #9
kciN
GOTCHA! Right, thanks Carsick! I see now.
New there had to be a valid reason..
Thanks..
Old 10-04-06, 01:53 PM   #10
svrash
water pump casing for 99 650 Styler Stuff Wanted 2 02-07-07 03:51 PM
A lo-cost solution to peeling water pump paint.. GooseSVSK2 SV Talk, Tuning & Tweaking 1 22-08-06 02:18 PM
crankcase and water pump auldyin Bikes - Talk & Issues 2 09-07-06 09:39 AM
Water pump on VW Passat rpwoodman Idle Banter 11 08-05-06 06:15 PM
Water Pump Leak greeno76 SV Talk, Tuning & Tweaking 2 24-04-05 04:56 PM
