Old 11-04-06, 03:25 PM   #1
tradedog
Default Cracked water pump cover?
I have just bought a crashed K4 S. On the right side of the bike where the large water hose comes from the radiator to the motor, the housing it connects to on the motor is cracked. Is this the water pump?
I have removed the three bolts securing it and the drain plug. The housing will move away from the motor but not come off it. Is there a trick to getting it off?
Anybody know what this part would cost to replace? Sorry, I am in Zimbabwe, no dealers here.
On another topic, on either side of the fairing inner there are 2 triangular holes, roughly where the clipons would go to on full lock. What should fill these holes.
My thanks in advance
Old 11-04-06, 03:36 PM   #2
NedSVS
I think you will have to remove the main casing on that side. See this entry on the forum http://forums.sv650.org/viewtopic.php?t=36268
Old 11-04-06, 03:42 PM   #3
Carsick
There should be plastic covers over those holes. I think the holes are there for adjusting the lights.
Old 11-04-06, 03:44 PM   #4
Spiderman
Where the hell am I?
Spiderman's Avatar
Hello all the way to Zimbabwe.
Yes it is the water pump cover, but from what i know you have to open the negine casing to fully remove the pump. There was a thread about this somewhere recently.
see here ... http://forums.sv650.org/viewtopic.php?t=36268
Old 11-04-06, 04:09 PM   #5
tradedog
Default water pump cover
Has anyone got a description of the sequence to remove the side cover? Where do I drain the coolant. I presume oil must be drained too?
Thx all
Cover for the Water Pump - Curvy Demonz Stuff Wanted 4 15-10-08 07:44 PM
water pump casing for 99 650 Styler Stuff Wanted 2 02-07-07 03:51 PM
WTB 2005 SV650s clutch water pump cover puffin04 Stuff Wanted 2 13-06-07 03:23 PM
crankcase and water pump auldyin Bikes - Talk & Issues 2 09-07-06 09:39 AM
Water Pump Leak greeno76 SV Talk, Tuning & Tweaking 2 24-04-05 04:56 PM
