Old 13-04-06, 05:04 PM   #1
big twin grin
Default Front Spring Preload
Guys and Gals,
Always been curious. Do the screw slots for each fork preload adjustment have to be aligned with each other. Mine are both pointing in, aligned with the cut out slots for the handle bars not in the same direction if you get what I mean. Always wondered?????
Old 13-04-06, 05:44 PM   #2
No. Just ensure that both adjusters are set at the same line.
But, if it bothers you, you could undo the clamp bolts and rotate the frok leg in the yokes 'til the adjuster slots were lined up.
But I think that could be considered a dab fussy.
Front Spring Question DANINPLYMOUTH SV Talk, Tuning & Tweaking 5 19-03-09 05:27 PM
Front preload query simesb SV Talk, Tuning & Tweaking 12 03-07-08 04:42 PM
front spring oil change etc jon8oy SV Talk, Tuning & Tweaking 7 18-12-07 06:31 PM
Another question about rear spring preload. oldjack SV Talk, Tuning & Tweaking 2 25-07-06 08:09 AM
Front preload caps on pre 02 model Fuzz SV Talk, Tuning & Tweaking 14 08-09-05 06:43 PM
