Old 17-04-06, 04:41 PM   #1
BIKER-DENE
Default gear box oil? mix? car?
what gear box oil can i use on my curvy sv? and is it ok to use car oil?
also can i mix different ones?
thnx
dene
Old 17-04-06, 04:52 PM   #2
Carsick
Isn't the gearbox in the sump oil?
Old 17-04-06, 04:53 PM   #3
BIKER-DENE
well engine oil what ever uw anna call it its all the same stuff init
bottom right hand side of the bike on the curvy
Old 17-04-06, 05:40 PM   #4
You can mix and match, but you only want to use oil that meets the JASO MA standard, and is it API SG? Means they won't cause your clutch to slip. Very few if any car oils have this, practically all bike oils do.
Old 17-04-06, 05:51 PM   #5
Well Oiled
API SG is just an oil API standard, not a specific motocycle oil. (the second letter goes up with each revision and we're now at API SM). An SG oil probably won't contain much in the way of friction modifiers (which cause the clutch problems), if any, because they don't have a high fuel economy test limit.
Old 17-04-06, 06:07 PM   #6
Yup, just mentioned that as it's a reasonable standard.
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
