Old 21-04-06, 10:57 AM   #1
VR46
Default Changing Sprockets for acceleration
I have a naked curvey '02
I want to change the sprockets to improve the acceleration, im prepared to sacrifice top speed as I never really need to go past 100mph.
What is the standard procedure in terms of sizes etc for this?
Rob
Old 21-04-06, 11:03 AM   #2
TSM
The Sick Man
TSM's Avatar
Do you want it to be a wheelie machine then lower the front sprocket to 14 which is equiv to somthing like 3 up on the rear.
Have a look here on sprocket info.
http://forums.sv650.org/viewtopic.ph...et+size#334248
Old 21-04-06, 11:08 AM   #3
VR46
So if i put a 14 on front I wont have to do anything to rear?
Yeah I wound like it wheelie without trying, if I went to a 14 on front any idea of what top end would be?
Rob
Old 21-04-06, 11:11 AM   #4
Viney
Rob
On my 's' i got about 125 at the top end, fuel dropped through the floor, and it was horrible on the motorway.
If you want a real wheelie machine, then go up 3 on the rear as well
Old 21-04-06, 11:22 AM   #5
VR46
If you want a real wheelie machine, then go up 3 on the rear as well [/quote]
I think that would be a bit too harsh,
Old 21-04-06, 11:22 AM   #6
cyphertheory
i got a k5s im gonna be riding thru london every day in the near future, not really a motorway user you think it would be worth my while to play with the sprockets for better performance around town?
Old 21-04-06, 11:29 AM   #7
Stormspiel
Going down on the front will increase chain wear though...There was a 49 Tooth Rear Renthal on Fleabay, and a 15 tooth front but it looks like the rears ended .
I've just ordered me a set of Silver 46Rr & 15Ft with a Tsubaki gold X-ring chain, £103.?? from B&C Express
Old 21-04-06, 11:32 AM   #8
TSM
The Sick Man
TSM's Avatar
Yep but supose your chain was fairly new and you wanted to change the sprockets, if you went up on the rear you would need to get a longer chain, but if you go down on the front you would not need to.
But its usaly better to change the chain and sprocket at the same time though.
Old 21-04-06, 11:33 AM   #9
thor
Really not worth it. Practice finding neutral instead. You'll be stopping quite often.
Old 21-04-06, 11:34 AM   #10
cyphertheory
lol yeah true enough, thanks thor
Changing Chain and Sprockets Fearg Bikes - Talk & Issues 9 21-01-07 11:05 PM
changing sprockets on sv650 k5 sv650nutter149 SV Talk, Tuning & Tweaking 11 24-04-06 12:58 PM
Changing Both Sprockets w.steele SV Talk, Tuning & Tweaking 3 20-01-06 09:17 AM
changing front Sprockets w.steele SV Talk, Tuning & Tweaking 4 13-01-06 12:37 AM
Acceleration Stan the Man SV Talk, Tuning & Tweaking 19 12-04-05 10:52 AM
