Old 22-04-06, 01:50 PM   #1
foxclarke54
Default Message to 21 Quest - Ben
Thanks Ben for your reply - (Front Fork Oil Change - Cagiva Raptor 650). You are pretty much spot on. I believe there is a nut below the top cap which I need to loosen to get the cap off. You're right in that there's no preload to worry about. I can follow the steps I have to take except bleeding the cartridge - How do I do that please??
A workshop manual is available but at a cost of nearly £50!! and there's little info of any sort on the net.
Any useful info you can email will be greatly appreciated.
MAIL ME AT: foxclarke54@yahoo.co.uk
Many Thanks
Graham
Old 22-04-06, 02:29 PM   #2
21QUEST
21QUEST's Avatar
Hi Graham ,
I don't know if you intended to a Private Message(pm). but if that was the case you need to click onto the 'pm' message to do that.
The files have been emailed to you.
To bleed the forks you need something to screw onto the damper rod so you can work it up and down. I've got a couple of tools with different thread pitch which I use. I guess at a pinch you can use a snug fit a piece of hose on the dfamper rod to do it.
Ben
Nemo me impune lacessit.
Garmin Quest Car Kit samssv Idle Banter 1 11-11-08 12:02 PM
Garmin Quest? hovis Bikes - Talk & Issues 12 30-10-07 12:29 PM
Employment Quest TSM Idle Banter 7 18-08-06 07:20 PM
Painting Quest TSM Bikes - Talk & Issues 18 16-07-06 04:29 PM
21 Quest and the disks Stig Soho Massive 0 27-07-05 06:34 PM
