Old 22-04-06, 06:13 PM   #1
doe
Default Bike won't start!!!!
Sorry to start new post. Got a honda rectifier and battery fitted, but bike won't start. the engine is turning ok. Please help.
Old 22-04-06, 07:38 PM   #2
doe
Bit of bad news - Just had the RAC round, there is no spark coming out of one coil. They suspect the ignition unit is gone. Is this expensive to replace?
Old 22-04-06, 07:41 PM   #3
Spiderman
Where the hell am I?
Spiderman's Avatar
sorry to hear that man.
I have no idea how much one of those is. Or truth be told what it even looks like
But google is your friend and someone may come along in a bit who knows.
Old 22-04-06, 07:43 PM   #4
Blue_SV650S
Disconnect/unplug the reg/rec and try again.
Disconnecting it will not do anything any harm, but it will eliminate this new part from the equation.
Obviously don’t ride off as your battery won’t be charging
Why did you fit a Honda reg/rec unit and what wired did you wire to what wires?
Old 22-04-06, 07:44 PM   #5
BILLY
There's some on EBAY I saw them a couple of days ago!!!! Do a search for sv650 parts you'll find them there!!!
Old 22-04-06, 08:07 PM   #6
doe
The old suzuki reg\rec got fried. Previous posts suggest the Honda unit work better.
I have wired red-red, Suzuki black to honda green(green is the earth on honda), the 3 yellows to yellows, The spare black wire on the honda reg/rec is suppose to be the voltage sensor, so it was connected to the signal fuse.
I will disconnect the reg/rec in the morning. But i am begining to think the rectifier took out a few other things. Right side indicator not working and no low beam or parking lights.
Old 22-04-06, 10:35 PM   #7
Swap the coils over, if the problem stays with that coil then it's duff, if the problem moves to the other cylinder then recheck the rest of the ignition system.
Old 23-04-06, 07:49 AM   #8
Tris
Good Luck mate, mine did the self-same thing and I'm only just (I hope) getting to the bottom of it.
I've checked every electronic component on the bike with the exception of the CDI. So that is now favourite
I've got one on the way (cheers Rictus ) but I'll let you know the out come once I get it.
Tris
Old 23-04-06, 11:26 AM   #9
doe
Thanks Sid, A bit wet 2day, not bothered. I will swap the coils over once its dry.
Tris, let me know how u get on. Look like i will be off d road 4 a few weeks.
Thanks
Old 24-04-06, 09:57 AM   #10
doe
Just wondering, i live on top of a hill and was thinking of doing a bump start. Will this work with one working ignition coil?(no spark out of the other) Its going to be one hell of a push back up.
Also, does the ignition coil control some of the electrics? My left side inicators are not working, change the bulbs, still not working.
My Bike Won't Start :( arcdef SV Talk, Tuning & Tweaking 34 01-02-09 08:38 PM
Help! bike doesn't start DJ828 Bikes - Talk & Issues 10 26-03-08 11:12 PM
bike won't start magicrat SV Talk, Tuning & Tweaking 9 16-02-08 02:31 PM
My Bike Won't Start! Yellow Bikes - Talk & Issues 4 01-09-07 08:31 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
