Old 22-04-06, 10:03 PM   #1
weazelz
Default running wide in corners with upgraded springs
hi sv650.org,
I've just bought an '00 650s & I like it a lot
only problem I'm having is that it seems to run wide in corners & need *loads* of steering input to make it round
the guy I bought it off had fitted +10% fork springs to it, so I was wondering whether this might screw up the handling. I am ~14 stone so I've bumped up the rear preload to pretty much max, & the rear shock seems to be okay, seems to be enough damping there
I was thinking maybe bump up the rear ride height or drop the 3-crown thru the forks a little .. any comments?
ta
~andy
Old 22-04-06, 11:04 PM   #2
HighSpeedAssault.com
Raise your fork tubes in the triple-tree's. Do it one-to-two millimeters at a time, till you get the desired geometry you R looking for. Raising the rear ride height is also do-able. Find out what the correct swingarm angle is and then adjust the rear height to that measurment.
Yes, fork springs will keep the front end from collapsing, thus 'lifting it. Put your rear preload back to its correct sag, check your front sag, correct swingarm angle, then make adjustments via triple-tree.
Old 24-04-06, 07:08 PM   #3
weazelz
I have raised the fork tubes ~3mm in the triple-crown & this has transformed the steering, much quicker & more positive
Old 24-04-06, 07:13 PM   #4
fizzwheel
fizzwheel's Avatar
How long have you been riding ? and also what tyres does your bike have on it at the moment ?
Oh and have you checked your tyre pressures lately ?
Old 24-04-06, 07:58 PM   #5
Excellent!
Old 24-04-06, 08:01 PM   #6
Good call!
We pulled our SV racebike out after a long winter storage and the bike was way slow steering. We went over all our measurements, all correct. ?!
Then one of my race partners says "how about we check the tires?" DOH!
Again, good call, as it is the FIRST thing on the checklist
Upgraded from SV650 to SV1000 ugp Bikes - Talk & Issues 35 16-01-09 11:08 PM
who has upgraded to firefox 3 timwilky Idle Banter 32 18-06-08 03:51 PM
Upgraded headlight bulbs tapemonkey SV Talk, Tuning & Tweaking 42 20-08-07 11:02 PM
Where to get my exhaust upgraded in the South-Eest, UK Rhubarb SV Talk, Tuning & Tweaking 9 16-10-06 02:47 PM
