Old 28-04-06, 07:47 AM   #1
andyb
Default Possible starting problem creeping in?
When I went to start it this morning and yesterday the engine turned over for longer than normal. Normally it fires up straight away but for the past two days it turned over for 5 seconds or so before firing up, any suggestions?
Choke was in same place, spark plugs have recently been changed. It was turning over quite fast so battery should be OK.
Thanks
Old 28-04-06, 07:56 AM   #2
Slightly warmer weather = bit less choke needed.
Maybe.
Give that a go first. If your bike isn't as easy to start but otherwise seems to run OK, first thing is check plugs.
Old 28-04-06, 10:27 AM   #3
andyb
Cheers Sid, I thought plugs as well but it starts perfect after work just not in the morning. WIll keep an eye on it and see what happens!
Starting problem. Stoneyginger SV Talk, Tuning & Tweaking 16 16-06-08 04:44 PM
Starting problem. gavinsky23 SV Talk, Tuning & Tweaking 8 28-02-08 09:31 PM
Another Starting Problem. Please Help!!! andyharding SV Talk, Tuning & Tweaking 20 11-09-07 05:53 PM
Starting problem..........again svrash SV Talk, Tuning & Tweaking 8 16-06-06 09:33 PM
