Old 02-05-06, 07:28 AM   #1
SpankyHam
Default Bike running very "lumpy" when top speed is reache
This morning on my way to work, I tested the top speed again on the private road section...
Once the bike is flat out it starts to jump
It jumps b etween 120 & 130 mph. It's not just the speedo indicating, the engine sounds strange & I can feel the bike pulling/stopping/pulling/stopping.
What's the matter with it now
Old 02-05-06, 07:42 AM   #2
TSM
The Sick Man
TSM's Avatar
Is it hitting the redline limiter? The SV should not be able to in 6th unless you are geared way diffrent.
Old 02-05-06, 09:43 AM   #3
pegasus
pegasus's Avatar
your hitting the limit patrick watch your revs...as a matter of interest my k4 could hit its limit in 6th no problem
tune in, turn on, burn out
pegasus is offline   Reply With Quote
Old 02-05-06, 09:56 AM   #4
TSM
The Sick Man
TSM's Avatar
Just read it again, it cant be the limiter unless the gearing is realy changed as at max revs you would be doing abt an indicated 135. Well on mine its like that and its geared +1 on the rear.
Old 02-05-06, 09:57 AM   #5
Razor
What is your jetting like?
Old 02-05-06, 10:56 AM   #6
Biker Biggles
Biker Biggles's Avatar
Sounds like what you are describing is your engine surging,which is more likely to be a fueling issue.Maybe a bit of fuel starvation at high revs?
Old 02-05-06, 11:22 AM   #7
SpankyHam
No the revs are fine.
will have to look into getting it rejetted.
I just put a fuel cleaner into the fuel system - might that cause it ?
Old 02-05-06, 12:28 PM   #8
SpankyHam
Been quoted £150 + VAT for a rejet
Old 02-05-06, 07:40 PM   #9
Razor
Not too bad I suppose. Cheaper to fit your own and not that hard to do.
Old 03-05-06, 06:26 AM   #10
SpankyHam
Absolutely fine again this morning.
I "think" it must have been the fuel system cleaner getting rid of some build up gunk...
Using "Pointy" Tensioners in a "Curvy"? dtr125 SV Talk, Tuning & Tweaking 25 05-02-09 05:42 PM
LCD Display shows "CHEC" after engine has been running for a while? Paul the 6th SV Talk, Tuning & Tweaking 8 10-12-07 08:39 PM
More "illegal" speed traps in North Wales Jelster Bikes - Talk & Issues 1 27-04-07 09:02 PM
Exhaust BHP Speed - I'm "Baffled" Kinvig Bikes - Talk & Issues 23 20-08-06 08:29 PM
