Old 05-05-06, 07:48 AM   #1
lukemillar
Default Furred metal
Is a wire brush and some hartd scrubbing action the best way to un-fur furred metal or is there something out there that I may spray/rub onto it that will clean it up?
Thanks
Luke
Old 05-05-06, 10:43 AM   #2
Razor
Not much you can do but polish it, which will mean it'll fur easier.
Prevention is better than cure.
Old 05-05-06, 10:56 AM   #3
SVeeedy Gonzales
Try ACF50 spray - Use it on my SV and the family pushbikes which are all kept outside. Stops rust on contact, keeps it at bay (and makes it look darker/oily so not so obvious anything has corroded) and doesn't wash off easily in the rain.
Old 05-05-06, 09:46 PM   #4
BILLY
use AUTOSOL that will bring it up
Old 06-05-06, 07:15 AM   #5
arr the furring sv bolts! i clean my bike like something possessed and still have trouble with this.
Old 06-05-06, 09:17 AM   #6
Warren
i found kurust "the rust treatment" chemical thats designed for turning rust back into metal works great on furred bolts, gives them a glossed over look and gets rid of the furring.
Old 06-05-06, 01:27 PM   #7
Aye, but they corrode again straight away... With kurust, you're supposed to rustproof within 24 hours. It takes away the corrosion, but leaves the perfet corrosion surface.
Wherever possible, take off the furred metal and throw it in the bin. Then clean up what you cna't remove (metal scotchbrite pad is my weapon of choice), ACF50 it, spray it again in a week, job's a good 'un. Stuff lasts forever.
Old 06-05-06, 03:56 PM   #8
Warren
i kurusted my metal screws and some other bits 2 years ago, and they havent rusted, or furred again.
(all weather rider, no time for cleaning )
Old 06-05-06, 04:44 PM   #9
might give that stuff a go.
Old 06-05-06, 06:38 PM   #10
Hmm, very odd. This was ferric metal, I take it? Kurust only reacts with iron oxide, on anything else it'll just cover it with an oily sheen. Doesn't do anything to aluminium oxide, for example, which is what usually causes the furry look.
can anyone identify this bit of metal 454697819 Idle Banter 3 17-06-08 09:53 PM
For the metal heads fat_brstd Thames Valley 9 25-03-08 03:43 PM
My Metal CDs on ebay Kinvig Idle Banter 2 11-01-08 10:41 AM
why? is heavy metal called heavy metal pegasus The Essex Lounge 14 09-06-05 07:26 AM
heavy metal !!! jaymz The Essex Lounge 52 04-06-05 08:58 PM
