Old 05-05-06, 09:34 AM   #1
Default bungee bars removal
Ok- saw in a thread from viney earlier that if you have high leverl exhausts u need to remove the n=bungee bars.
set methinking>? should I remove mine with n angle grinder- just for sometic purposes.
i dont use them!...
would look sleeker without them
but-
whats yer opinions?... on re sale etc if I cut em off !
Old 05-05-06, 09:57 AM   #2
You'll want to spray with a suitable protective paint afterwards or coat them to prevent rusting... I'm chopping up a subframe to remove unwanted bits, of which there are quite a few- though I'll be leaving the rails, they're quite handy. I use the RHS one for luggage and the left has the shock reservoir bolted to it
A straight subframe can be had for under £40, usually, so if it does affect value it'd be simple to change it back.
Old 05-05-06, 10:30 AM   #3
cool
ta for the advice matey ... ..
Old 05-05-06, 11:15 AM   #4
Viney
Default Re: bungee bars removal
i dont use them!...
but-
You dont have to remove them for a high level, only the Renegade underseat kit. However, an angle grinder is the tool to use, then a coat in hammerite should be the job
Old 05-05-06, 02:15 PM   #5
haggis
Quiff, I had great satisfaction in hacking my subframe up.
What did you intend to do for an undertray afterwards? It leaves two huge ugly holes in the underside of the tail, be that standard plastic shovel or even an aftermarket tidy jobbie.
I made a template and cut a sheet out. It runs from the tail light right down to the battery box/crud flap. Much slimmer and cleaner looking now. Even better load space under the seats as I hacked all but the battery holder from the black plastic. Room for a pair of trainers, tools, lube, waterproof trousers. Ace!
Only downside is when I wanted to carry a tailpack, it was quite hard to strap it down and not have it slipping backwards or side to side. I'm going to add four M8 bolts to the underside for hooking onto in future.
Like so....
Old 05-05-06, 02:30 PM   #6
i dont use them!...
but-
OOO my technical know how is exposed.!! ..
it was just that which made me think do i need them??? and then I stood looking at it imagining them not there and hmmm I liek the idea.. but - north meets south and AR06 to do and camping!.. i may want them on!..
Old 05-05-06, 02:32 PM   #7
Like so....
yea thats the kinda look I am after.!
however I will need to peruse it a bit more-- dont want to act in haste and repent at leisure... maybe I havent had a ood enough look (need to se how these holes would be and where) before I get my big boys toys out !!
bungee straps (without the big plastic hook) hovis Idle Banter 7 08-08-08 12:29 PM
Bungee and Mad waterski show Jester666 Guildford Massive 1 23-08-07 04:18 PM
Bungee and and waterski show Jester666 SELKENT 0 23-08-07 10:34 AM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
SV650S bars for SV650 bars? MikeC SV Talk, Tuning & Tweaking 11 08-12-06 12:34 PM
