do you need to remove the wheel bearings when powder coating and is it a hard job to and how much ruffley are a new set
#2 | |
replacements, Mrs suzuki will charge you something like £35 for them, but if you take the old ones to a bearing place (I've used bensham bearings in Croydon before and a place in Enfield0 you can normally get double shielded (the originals are single shielded) one for about £6-8 each. Cheers Mark.
is Doubl-shielded better then? and why?
i know nothing about bearings, ![]() Paul |
#4 | |
#5 | |
The Sick Man
There are 2RS type which have rubber seals and there are another type ZZ which has metal sheilds. The rubber resists water better but cannot rotate as fast than the ZZ type. Im not sure at what level this actualy matters.
Found this page re info on bearings. http://www.gizmology.net/bearings.htm
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
top bombing any one used the powder coating place in mitcham or can recommend any in the london area
powder coating | FG1 | Idle Banter | 17 | 13-01-09 09:43 PM |
Powder Coating - Where? | Demonz | Guildford Massive | 16 | 19-04-08 07:29 AM |
powder coating | weazelz | SV Talk, Tuning & Tweaking | 6 | 02-10-06 10:57 PM |
Powder coating, where? | Skullmonk3y | Bikes - Talk & Issues | 3 | 29-05-06 10:56 PM |
Powder Coating | Jelster | Bikes - Talk & Issues | 22 | 14-04-05 08:25 PM |
