Old 10-05-06, 04:35 AM   #1
johnlennon1
Default Cam louder then exhaust..VERY loud!
I was on this site a year ago about my cam noise and found it to be "normal"
. 3k miles later and I was driving and the cam noise got very loud and poped the clutch in and the engine stalled. It will run however, the (cam) noise is louder then my aftermarket exhaust!! What could it be...bad cam chain, tensioner, shim... Your help is needed.
20k and have no idea who the 1st owner was?
Old 10-05-06, 07:50 AM   #2
andy
Doesnt sound good, cam chain tensioner is the likely candidate as they are known to be weak but you will need to take the cam cover off and have a look to inspect the damage the loose chain may have caused.
Good luck.
Old 10-05-06, 10:20 AM   #3
JakeRS
my cam noise has turned out to be resonance, tho if it changes when you pull the clutch in i guess you're in less luck..
Louder! (without exhaust change) sauluk SV Talk, Tuning & Tweaking 20 04-04-09 01:18 PM
Wanted - louder exhaust for curvy phuk72 Stuff Wanted 4 09-12-08 10:06 AM
i want a loud exhaust now ! tonyk SV Talk, Tuning & Tweaking 11 15-11-07 11:37 AM
Why was my exhaust sooooo loud TSM Bikes - Talk & Issues 0 14-08-06 10:21 PM
louder original exhaust? fabio SV Talk, Tuning & Tweaking 11 18-09-04 09:46 AM
