Old 12-05-06, 12:41 PM   #1
SVNez
Default clutch problems...
Hey all, it's been a while since I last posted but here goes...
Ok I'll try and keep this short & sweet, I had a slipping clutch recently, so decided to replace the plates, this seemed to remedy the problem as far as "normal" riding is concerned, but last night when I had to give it a bit of a handfull it started slipping again - so, it seems ok under normal acceleration etc.. but not hard acceleration... could the springs need changing also? any ideas? anyone?
ta!!
Old 12-05-06, 12:57 PM   #2
r4ce_e3nd
did you drain the plates in engine oil befor mounting them? I've read this is realy nessecary (how do you write this word )
harder springs will help, though...
Old 12-05-06, 03:06 PM   #3
johnnyrod
johnnyrod's Avatar
Sounds like you need to make friends with the clutch lifter adjuster. This is under the front sprocket cover, or round there, where the cable goes in. Adjustment is in the manual, basically it's a screw so when the cable pulls it turns, screws in, pushes the pushrod through to the clutch, and lifts the clutch centre. Take out all the cable tension, slacken the locknut of the adjuster screw, wind it in till it touches the end of the pushrod, then back it off a quarter of a turn. Hold it and tighten the locknut. You should then be able to pull the cable and feel just a little slack before the pushrod starts being pressed. Put back together and adjust up. If the adjuster screw is too tight then you'll never get full compression on the clutch springs on the plate, and in the higher gears with a big handfull it'll slip.
Or if you've done all that, you've not used something other than just m/c oil in the engine have you?
Old 12-05-06, 03:34 PM   #4
lukemillar
necessary
At school they used to say think of a shirt with 1 collar and 2 sleeves - necessary. A bit stupid really, but I have never forgotten it!
Old 12-05-06, 06:46 PM   #5
r4ce_e3nd
necessary
RESTEPC!
they never teached me that at school...
Old 12-05-06, 08:23 PM   #6
scobysv
necessary
RESTEPC!
Old 12-05-06, 09:20 PM   #7
Biker Biggles
Biker Biggles's Avatar
Taught,they never taught you that at school.Not teached.
Anal retention session over.
Old 13-05-06, 01:18 AM   #8
http://forums.sv650.org/viewtopic.ph...=clutch#451408
Old 13-05-06, 06:40 AM   #9
r4ce_e3nd
lol, they realy didn't taught my much at school...
that's for sure!
Old 13-05-06, 07:11 AM   #10
Stig
Originally Posted by Sid Squid
Youv'e been using that Search function on this forum again haven't you.
Good innit. Maybe we should have it in BOLD and huge font.
Clutch problems. otacon88 SV Talk, Tuning & Tweaking 13 16-05-09 06:19 AM
Clutch 'Selection' Problems. Grinch SV Talk, Tuning & Tweaking 32 19-08-08 10:32 AM
Clutch problems. chakraist SV Talk, Tuning & Tweaking 13 03-02-08 06:03 PM
Clutch problems from new dmracing SV Talk, Tuning & Tweaking 3 03-08-06 01:00 PM
Clutch problems? PWNDLOL SV Talk, Tuning & Tweaking 1 05-07-06 07:10 AM
