Old 15-05-06, 09:15 PM   #1
Blue_SV650S
Default Uprated Brakes
I have a curvy, I don’t know if they improved the front brakes on the pointy?, but lets face it one word describes the SV’s front brakes ‘uninspiring’!!!
I have braided hoses and new pads, but they are still a little lacking for my taste really.
I am not going to get stupid and buy some aftermarket setup, so my question is! Are there any 4pot callipers (and accompanying master cylinder) that fit directly on the SV forks and disks??? … say off a GIXER6 or even from a different manufacture, say off an R6?? That way I could hopefully source a 2nd hand set and whack them on, job done!!
Old 15-05-06, 09:26 PM   #2
No. For the Nth time.
Look here: click click
Old 15-05-06, 09:31 PM   #3
Carsick
{ ANSWER = FALSE ^ N >= 1 }
Sorry, been doing formal methods all day.
Old 15-05-06, 09:34 PM   #4
svrash
Yes you can
do a gixxer front end swap
Old 15-05-06, 09:41 PM   #5
Viney
Or buy those expensive brackets from the states, and fit gixxer calipers to your bike. Just remember though, the brake will be better than the front suspension
Old 15-05-06, 10:06 PM   #6
Aaaahhh shaddup!!
Old 16-05-06, 08:23 AM   #7
Blue_SV650S
So no one has found any callipers that fit directly on, from ANY bike from ANY manufacturer??? That’s a little surprising, but not unbelievable I suppose, what a shame
The brackets look a bit gormless!!! They are not cheap either!!!
Old 16-05-06, 08:26 AM   #8
Razor
BILLET MINI 6 calipers will bolt straight on, look the dogs too.
They're about £550 a pair
Old 16-05-06, 09:08 AM   #9
Yup... Said it before, but IMO the cost of the brackets, the calipers, and the suspension work to make it work is high enough to make it money wasted. If you've already got uprated standard forks then it could be a good option.
Old 16-05-06, 10:17 AM   #10
Blue_SV650S
Originally Posted by northwind
Yup... Said it before, but IMO the cost of the brackets, the calipers, and the suspension work to make it work is high enough to make it money wasted. ...
Indeed!!!
Hence back to my original thought …. there must be some callipers off some bike that fit directly on?!?!!?
All this said about 4-pots, the brakes on my old CBR6 were only 2pot, yet they felt pretty good (compared to the SV), so although floating calliper is technically inferior to 4-pots, there are better setups … perhaps it is the mastercylinder that is the week point on the SV, not the callipers?!?!
Has anyone fitted a different mastercylinder to the standard callipers?!?!
I have a master cylinder for a 4-pot setup, but I presume that the ‘ratio’ (amount of fluid pushed for given piston movement) would be all wrong if I try and use that with some 2pot?? Any thoughts on the master cylinder??
Uprated Shiny Curvy Forks petevtwin650 For Sale - SV's and SV related items 6 20-09-08 12:15 PM
Uprated bulb discussion Baph Bikes - Talk & Issues 12 17-07-08 09:04 PM
uprated bulbs ...again hovis SV Talk, Tuning & Tweaking 32 09-03-07 09:43 AM
Uprated springs RingDing For Sale - SV's and SV related items 8 08-03-07 07:34 PM
uprated cams 01 sv650s SV Talk, Tuning & Tweaking 5 08-10-06 07:21 PM
