Old 22-05-06, 12:02 PM   #1
Iansv
Default Changing rear shock.... How easy/hard
Bearing in mind my numptyness at mechanical matters should I attempt this myself...
Anyone done it recently, common issues ? I have an abba stand, so I presume I just get the wheel out the way and loosen nuts/bolts and just swapover... ? Its an identical shock
Old 22-05-06, 12:04 PM   #2
Diveboy
Never done it mainly because you have to have the back end unloaded so you will need an abba stand or some way of suspending the bike.
I dont have either.
Old 22-05-06, 12:34 PM   #3
It's pretty easy. Fiddly in places just because of access, and the linkage bolts will be hard to shift if they've been untouched from birth. You don't need to remove the wheel either, though it does make things simpler (I don't). If you've got a full system fitted, you'll maybe have issues with the headers being in the way.
You'll want to check and grease the linkage bearings... TBH, there's a good chance they'll be a bit ****ed. It's a killer combination of out of sight and mind, but exposed. But at the very least, get in there with some new grease.
Old 22-05-06, 01:22 PM   #4
fizzwheel
fizzwheel's Avatar
I've got a new one on the way to. Ian we can be mechanical numptee's together.
Old 22-05-06, 01:58 PM   #5
petevtwin650
I agree with Northwind. Pretty easy with an Abba stand. The linkage bolts will be the problem ,firstly by being probably seized, and by the difficulty to get on them. Be a perfect opportunity to grease everything as well.
Old 22-05-06, 04:45 PM   #6
Caddy2000
Fancy a threesome?
Should be getting my Ohlins this week, and I already have an ABBA stand........
Ian - what ya got?
Old 22-05-06, 04:56 PM   #7
mattSV
mattSV's Avatar
Fizz - I have got an abba stand if you need one mate
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 22-05-06, 05:02 PM   #8
fizzwheel
fizzwheel's Avatar
Nah its OK ta. My dad has a bike lift in his garage that he uses when hes working on his old British stuff. I'm going to take the SV round to his house and use that. Cheers for the offer though
Old 22-05-06, 05:29 PM   #9
Caddy2000
Just out of curiosity, what old brit stuff has he got?
Old 22-05-06, 05:36 PM   #10
fizzwheel
fizzwheel's Avatar
He's got 3 at the moment
1930 BSA 250 single
1930 ( I think ) BSA 350 Single "Sloper"
1948 Matchless G50 or G80 500cc single
Changing the Rear Suspension (adjusting standard shock) Larry SV Talk, Tuning & Tweaking 18 31-08-09 01:23 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
How easy - install rear hugger & belly pan Kinvig SV Talk, Tuning & Tweaking 11 17-10-07 09:11 AM
Rear Cam Chain Tensioner - Easy way to remove? (Curvy) Ter SV Talk, Tuning & Tweaking 3 15-11-06 09:54 AM
changing the shock BIKER-DENE SV Talk, Tuning & Tweaking 6 22-07-06 10:42 PM
