Old 24-05-06, 05:34 PM   #1
robz400
Default Chain Maintainence
Right i've done 1500 miles on my new svs and the chain needs adjusting...
No problem me thinks... sorted that all the time on my bandit 4, but that had a centre stand....
I'm a bit stuck, is there a way of adjusting the chain on my own with the bike on a side stand, or do i need to fork out on a paddock stand??
Old 24-05-06, 05:40 PM   #2
Stig
Yes.
Tip the bike over on the side stand until the rear wheel is off the ground. Then slide something under the exhaust where the front pipe meets the rear one.
I used to use a brick, but basically what ever is available will do.
Old 24-05-06, 05:43 PM   #3
chazzyb
A short piece of wood under the swing arm near the rear caliper also works. Me? I've got a centre stand (smug git)
Old 24-05-06, 05:44 PM   #4
robz400
sweet, thanks!
I'll give it go. Figures crossed in ten mins the won't be a "I've dropped my bike in the garage tread"!!!!!!!!!
Old 24-05-06, 06:02 PM   #5
TC3
The cost of a paddock stand is lil compared to the risk of dropping the bike!
Old 24-05-06, 06:10 PM   #6
Stig
Do you think I should have also mentioned it might be an idea to tie wrap the front brake
Nah, I'm sure he will have thought about that.
Old 24-05-06, 06:19 PM   #7
No need to lift it up - it can be adjusted just fine on it's wheels.
Old 24-05-06, 06:29 PM   #8
Stig
This is true, but do you not check for tight spots every time you adjust the chain?
Easier to spin the wheel with the wheel off the ground rather than having to either walk the bike check the chain, walk the bike check the chain. Or keep tipping the bike to spin the wheel.
Old 24-05-06, 07:07 PM   #9
robz400
Yea ok didn't think of that!, but hay-ho it worked fine!
Thanks for the help...
Old 24-05-06, 07:18 PM   #10
furkuk
Mine has done 8500 miles and I haven't had to adjust it yet, I am putting it down to the Scottoiler cus on my Bandit my chain was ruined by 7000miles
General maintainence question on a new SV.. Welsh_Wizard SV Talk, Tuning & Tweaking 13 15-10-07 11:32 PM
Sidi Vertigo's - maintainence muzikill Boots 1 09-08-07 12:04 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
