Old 27-05-06, 03:27 PM   #1
carlSV
Default Rear suspension
Could anyone tell me what the differrence is between a 2000/2001 gsxr1000 rear shock with a red spring and a 2004/2005 gsxr1000 with a yellow spring, Cheers
Old 27-05-06, 04:07 PM   #2
lukemillar
Have a look at this table - differences should be spring rate (in lbs) and length.
HTH
YEAR MOTORCYCLE LENGTH SPRING
00-03 GSXR750 325mm 400#
01-03 GSXR600 325.5mm 325#
01-02 GSXR1000 329.5mm 430#
03-04 SV650 330mm 430# <<<==== stock 2nd gen...05 should be the same
99-03 GSXR1300(Busa) 330mm 700#
04 GSXR750 332.5mm 408#
04 GSXR600 332.5mm 425#
03-04 GSXR1000 332.5mm 480#
99-02 SV650 337mm 510# <<<====stock 1st gen
04 ZX10R 338mm 540#
03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks!
96-99 GSXR750 345mm 375#
97-00 GSXR600 375mm 375#
05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com
Old 27-05-06, 05:34 PM   #3
Blue_SV650S
HTH
Wow that is really useful, good work
Ok so I have a curvy (sorry to hijack thread ) … so 99-02 SV650 337mm 510#
Looking at the list my most sensible upgrade would be either of these two:-
04 ZX10R 338mm 540#
Do you know if they are a direct fit?
Old 27-05-06, 06:28 PM   #4
lukemillar
HTH
04 ZX10R 338mm 540#
I do believe so. On my pointy, I had to cut the battery box so that the shock's reservoir would fit so I'd imagine you'd have to do something similar. Have a look at this:
http://forum.svrider.com/index.php?P...opic=48973.210
It's where the table originates from. Also talks about rider's weights and the sort of spring rates that you should be looking at. It is a 17 page monster, but I'm sure you'll find everything you need!
Old 27-05-06, 06:47 PM   #5
carlSV
Cheers for that, I`ve got a 04 naked, So the 03-04 gsxr 1000 shock would be the best option. There is a bit of modification to fit the shock, which I`ve read about
rear suspension set up walkaboutandy Thames Valley 0 13-03-09 04:27 PM
Adjusting Rear Suspension on SV Stoneyginger SV Talk, Tuning & Tweaking 5 27-04-08 06:29 PM
Rear Suspension Joints I'm_a_Newbie SV Talk, Tuning & Tweaking 1 03-05-07 05:40 AM
rear suspension stev SV Talk, Tuning & Tweaking 10 11-06-06 11:11 PM
the sv's rear suspension kwak zzr SV Talk, Tuning & Tweaking 12 31-08-05 07:06 PM
