Old 28-05-06, 07:37 PM   #1
pingu
Default Removing the tool box
Some aftermarket rear huggers require the removal of the tool box. Not sure if I am comfortable with doing this as I would have to relocate a % of the tools but how easy is it to do?
It's plastic but is it screws or cut out? I am assuming removal of rear wheel (temporary ) would give better access.
Pingu
Old 28-05-06, 07:54 PM   #2
BILLY
Leave the tool kit at home and join the AA
Old 30-05-06, 07:25 PM   #3
motorolly
Tool kits are for Harley's and Italian bikes
Old 30-05-06, 07:27 PM   #4
Carsick
I have my toolkit under the pillion seat with a fairly long chain.
Old 30-05-06, 07:31 PM   #5
pingu
So it is easy to remove?
Old 30-05-06, 10:37 PM   #6
mart
i found it easer to remove the undertray to do it but if you have a dremel thats the tool for the job remove the box below the lip of the battery box and drop a thin peice of aluminium below the battery and mastic arround it to seal the battery box job done and it makes the rear end look higher
Old 30-05-06, 11:06 PM   #7
pingu
Got any pics Mart?
Old 31-05-06, 06:03 PM   #8
mart
best i can do for you at the moment will try to get one later
Old 31-05-06, 10:39 PM   #9
lukemillar
I'm not sure if this is possible (though I'm sure someone will correct me ) but would it not be possible to source a K3 undertray as they don't have the tool box under the battery? I know the rear subframes are slightly different, but surely a little jiggery pokery would make it fit?
Old 31-05-06, 10:48 PM   #10
Carsick
I have a k3 undertray that I was planning to fit at some point this summer. I'll let you know if it can be persuaded on.
SV Tool Kit/Spark Plug tool svdemon Stuff Wanted 1 17-12-07 12:29 PM
tool for removing swing arm and engine fat_brstd Stuff Wanted 6 08-05-07 12:00 PM
Has anyone got this SV tool? Daimo SV Talk, Tuning & Tweaking 12 08-08-06 11:08 AM
Tool Help Ceri JC SV Talk, Tuning & Tweaking 6 09-06-06 11:07 AM
Best tool ever? embee Idle Banter 9 17-02-06 10:13 PM
