Old 02-06-06, 02:20 AM   #1
old duffer
Default Oil starvation and pick up
Hi everyone, I just bought an SV 99 model I think and I've heard stuff about oil starvation when doing wheelies. I was going to give the stunting away when I sold my GSXR but couldn't do it
I've done a couple of searches and not much came up.
What's the deal with the baffle plate and could it be put in mine?
Anyone have any ideas on how do make an oil pickup that works properly? I have no problems manufacturing it but no idea with the design.
Keeping the revs low isn't a problem either.
Old 02-06-06, 02:25 AM   #2
old duffer
Also, does this model have a tip over sensor?
Old 02-06-06, 05:03 AM   #3
John Burt
From memory only the really early models didn't have the oil baffle plate fitted, the details are in the official manual somewhwere.
Old 02-06-06, 09:48 AM   #4
There's a lot of people who'll tell you that it's posible to modify it... But I've never seen anyone say they've actually done it.
Old 03-06-06, 01:24 AM   #5
RandyO
99s didn't need a baffle plate cause they had the baffle cast into the crankcase
early 00s they did away with the casting to save a few grams of weight and prolly 3pence in manufacturing cost, a so called "improvement"
it was quicky discovered that without the baffle, the oil would cavitate the oil pump, the few thousand that were made were recalled, and the baffle was retrofitted back in
AFIK no one has succesfully relocated the baffle to prevent loss of oil while wheelieing
my opinion is to devise a dry sump system for the SV
Old 03-06-06, 02:28 AM   #6
old duffer
Interesting... how does a dry sump work?
Thanks for all the input so far. Keep the ideas coming please
Old 03-06-06, 07:26 AM   #7
facade
Dry sumps are fitted to amongst others, Rotax engines (eg aprillia), Harley Davidsons, Buells.
There is an oil tank fitted to the frame that feeds the normal oil pump.
A second oil pump sucks any oil from the sump and returns it to the tank.
The sump is virtually empty when running, hence "dry sump".
I'm not sure of it's value in a road bike, you end up with a hot tank to burn your leg on, or in the case of the aprillia pegaso, to heat the headstock, and make the steering bearings fail. It would help with stunts though.
Old 03-06-06, 11:54 AM   #8
G - renamed
There's some pro-stunter around that uses an SV, so it can be done.
I've just added a bit more oil to mine and am hoping it'll work... I do have a complete spare engine in bits if it doesn't, though .
My wheelies still aren't perfect, but i can keep it up for a reasonable distance, at least - just kinda got the balance point sorted on the TRX, but need a bit more practice on the SV.
Old 03-06-06, 12:28 PM   #9
old duffer
I emailed Dan from scootertrash in michigan but he doesn't have the internet... apparently he sorted something out so it didn't run out of oil. He's been through 5 or 6 motors I've been told though. I know Christian Pfeiffer used one before being signed with Ducati also but haven't got around to asking yet .
Old 03-06-06, 07:00 PM   #10
Christian Pfeiffer used to take a spare bike to every show though- his approach was just to blow them up and swap over.
Oil starvation when wheelie - ing?! Dappa D Bikes - Talk & Issues 45 09-06-09 03:12 PM
Pick up my sv next week.... Stoneyginger SV Ecosse 32 28-03-08 08:33 AM
Just off to pick it up!!!!!! EarlyBee Bikes - Talk & Issues 11 17-10-07 12:55 PM
Pick your brains?? scarlett Bikes - Talk & Issues 11 24-04-07 08:19 PM
Pick and Mix Your Own Law Balky001 Idle Banter 48 18-08-06 06:24 PM
