Old 05-06-06, 07:52 AM   #1
peterjohnwood
Default Help....Chain Snapped Metal Thing Broke
Hi,
Hopefully I can get some help here. My chain snapped the other day and I came to sort it out and I realised that a metal rod from the clutch mechanism has broken. Does anyone know what this Rod is and if I can replace it with ease.
SV650S K4
Many Thanks
Pete
Old 05-06-06, 07:53 AM   #2
Viney
Is it the one that the clutch mechanism pushes against to operate the clutch?
Item 15 on this Fiche
Old 05-06-06, 07:55 AM   #3
peterjohnwood
Yes I think it is.
Old 05-06-06, 07:56 AM   #4
Viney
Originally Posted by peterjohnwood
Yes I think it is.
Sorry, item 15 on this Fiche
If so, its replaceable.
Old 05-06-06, 08:00 AM   #5
creamerybutter
If I remember correctly it will set you back about £8 from a dealer. Or at least that is what they quoted me.
Old 05-06-06, 08:11 AM   #6
peterjohnwood
Any idea how to remove the broken bit which is still connected to the clutch? Or should it just pop out?
Old 05-06-06, 08:20 AM   #7
creamerybutter
Actually ignore me I got the wrong bit so I don't know I am afraid.
Old 05-06-06, 10:47 AM   #8
Addick
I don’t know if it’s the same for the SV but when the chain on my Thundercat broke it took out the link rod as well.
The remains of the link rod just pulled out and I replaced it with a new one,
check the condition of the oil seal !
Old 05-06-06, 06:22 PM   #9
slider
hi m8y. if its the same as my old thundercat you may be able to just pull it out with a magnet , if not side casing off the other side of the engine, got mine out that way . oh and its called a clutch push rod if i remember right.
Old 05-06-06, 08:25 PM   #10
454697819
on the old sv it falls out of the external clutch mechanism realy easy, but if it has snapped off inside then ohh eck,,, i think a long thin maghnet should do the trick..
i went though one aswell... 180 miles away from home...
hope all swell
OE Chain snapped! Maverick Bikes - Talk & Issues 20 02-07-08 09:10 AM
Snapped chain, no fun JimmyGulp SV Talk, Tuning & Tweaking 13 24-07-07 04:25 PM
Blasted thing broke down -Ralph- SV Ecosse 17 06-02-07 03:16 PM
Chain broke :-( RobSV The Essex Lounge 24 09-04-05 01:35 PM
Chain broke at low speed... please advise !!! ash SV Talk, Tuning & Tweaking 21 10-01-05 02:05 AM
