Old 08-06-06, 08:57 PM   #1
Default MOT question
So, the Northwindmobile is MOT-ed up for another year, thanks to the friendly local garage and their liberal attitude to exhausts. But something came up that I was sort of expecting would...
I removed the sidelight when I did the respray, since it was pretty ugly, and added no light worth mentioning. Now, my read of the MOT regs says, "A motor bicycle (with or without a side car) fitted with a headlamp need not have a front position lamp (but must have one on the side car, if a side car is fitted).". But I was told today that technically, I should have been failed for not having one. As far as I can tell, if it's there it has to work, but if it's not it's not required. Anyone?
Old 08-06-06, 09:09 PM   #2
BILLY
I think as long as you have a pilot light which also works a a park light that's all you need!!!!
Old 08-06-06, 09:14 PM   #3
Warren
ok, im gonna ask further.
(as were now officially rebuilding a bike)
does a bike have to have a sidelight ?
what if there is no sidelight/parking fitted (were talking that little stupid led thing that no one uses)
can we get away with just removing the bulb, therefore technically not having one fitted, or do i need to remove the switchgear bit too ?
its gonna be a pain in the ass to fit a sidelight as most aftermarket headlight units dont have provisions for one.
(i might just use a hornet or SV headlight)
Old 08-06-06, 09:18 PM   #4
Biker Biggles
Biker Biggles's Avatar
I use that parking light on the SV. It's put there so that you can drain your battery while the bike is parked up at work all day.
Old 08-06-06, 09:21 PM   #5
Warren
on the CBR's (that were streetfightering)
there is no option for a parking light, therefore you need the keys in the ignition to have it on.
Old 08-06-06, 09:56 PM   #6
That was the question I just asked wasn't it?
Old 08-06-06, 11:07 PM   #7
facade
My Bros does not have a pilot light, nor a position on the switch for it. (Japanese spec)
It MOTs no problem.
It is headlight and taillight or no lights at all.
Conclusion: a bike does NOT require a pilot light.
Old 09-06-06, 07:56 AM   #8
falc
Plenty of bikes seem to not have them, I guess if you have it, it must work but if you've removed it then it should be ok...anyone got a proper answer
Old 09-06-06, 08:10 AM   #9
Viney
Falc, ALL bikes have them, just sometimes they aint seperate and are built into the headlights.
Old 09-06-06, 02:38 PM   #10
haggis
OK, i think in your case northy the answer is NO, not required for an MOT.
see here
(that's the second time i've linked to there today, I should be on commission)
In short, I read that as....
If you don't have a headlamp you must have a position lamp or it will be recorded as a daytime only machine.
If you have a headlamp, it is not a requirement to have a position lamp.
HTH.
MOT Question DanDare Bikes - Talk & Issues 4 04-03-08 01:48 PM
R&G bar end question lukemillar SV Talk, Tuning & Tweaking 1 21-03-06 10:27 AM
Bhp Question kashby SV Talk, Tuning & Tweaking 4 07-05-05 11:39 AM
N.I.P. Question? Cronos Bikes - Talk & Issues 19 21-04-05 11:21 AM
