Today i was changing my oil and oil filter then when i started my bike oil sprayed everywhere, i noticed iv damaged the seal on the bike where the oil filter connects when u screw it in. when i get time il drain all the oil and try fix this problem myself but i get a feeling the rubber seal may need replaced. has this ever happened to anyone before? and if so can you give me any advice on how to repair or maby you know how much it costs to repair?.
![]() ![]() The oil filter comes with a rubber seal, which seals onto the metal of the engine casing. Are you sure you tightened the new filter well enough? Maybe you have a bogie filter, have a look to see if the rubber is cut, and try and exchange it off the shop you bought it. |
Have you not left the seal on the bike instead of removing it with the old filter?
#4 | |
Did you smear a little fresh oil on the rubber to help it seal OK?
Or have you cross-threaded the filter? ![]() |
sound slik eu say that took old one of... and the seal stayed on
then put a new filter on with seal>. so now two seals...! wouldnt be ace would it... and boom aleak. matey - just take the filte roff.. u may find 2 seals.. keep the one nearest to the filter and chuck t'other.. smear some oil around it- but sounds like htreres plenty there already .. and tghten it up depends how u get the oil filte roff i suppose.. if u have a wrench.. I use a screwdriver banged through it..So I would have to invest a tenner in another new filter--- which i would prob do anyway .... dont htink u will need to renew oil will ya guys- just maybe top up.. as u will lose some... but i would take the oil filter off when the engine is cold...
ooops I did it again ... new bike . cb1000r |
Jst come back in from the garage, i examined both filters and yes i reckon when i took the old filter off the rubber seal has stuck with the bike lol. iv been changing filters for years and this has never happened
![]() Thanx for the advice i only jst added this thread a few hours ago and didnt expect so many responces ![]() |
#8 | |
#9 |
my plan is too drain the oil into a clean bucket then deal with the oil filter and refit that and top up the oil. But if i was to just remove the oil filter how much oil would i be letn escape? does the whole engine get drained or is it just a fraction of oil being lost?
#10 | ||
Front Car Tyre Burst - Need Two? | krhall | Idle Banter | 12 | 12-03-09 02:54 PM |
ultra seal? | ben650 | SV Talk, Tuning & Tweaking | 9 | 20-03-07 11:49 PM |
My bubble has been burst..... | DanAbnormal | Bikes - Talk & Issues | 7 | 14-05-06 12:42 PM |
burst battery | Big Bad Al | SV Talk, Tuning & Tweaking | 13 | 22-03-05 09:41 PM |
To filter or not to Filter.....are you feeling lucky? | Magoo | Bikes - Talk & Issues | 40 | 02-12-04 05:17 PM |
