Old 13-06-06, 10:33 PM   #1
martin_SV
Default switch to disable headlights on always on SVS models
Anyone fitted a headlight overide switch to the newer always on models?
I have a K3 svs and wonder if anyone's found a conveniently placed wire that feeds both headlights which can then have a switch inserted. ( NB In case you're wondering on my previous model with a light switch I did have the hlights nearly always on but I just like to hyave the choice ) :D
Old 14-06-06, 06:28 PM   #2
Robw#70
On earlier Gsxr's some imports had lights on all the time, wheras the uk ones were switched.
Suzuki only changed the switchgear with all the wiring staying the same in the plugs so it was just a case of plugging in a new switch in.
Might be worth looking at other models to see if its possible
Old 14-06-06, 07:59 PM   #3
sv650s_guy
you are not legally aloud to anymore as eu say all new bikes have to have lights on all the time
Old 14-06-06, 08:12 PM   #4
I don't think that would work on then Pointy SV, it was designed and constructed as lights on, thus the wiring doesn't have the necessary plugs for alternative switchgear with a switch.
If you want to switch the lights you'll need to break and switch the orange wire in the left hand switchgear, (it's internal), but after the branch for the headlamp flasher or that'll be disabled when the lights are switched off too, you'll need to use a two pole switch and switch the brown wire from the ignition switch that supplies the rear light and the front position lights as well, this cable also supplies those two for the parking light function - if the switch is off the parking lights won't work - and the live auxiliary terminal too, if the switch is off that won't be live.
Old 14-06-06, 08:40 PM   #5
this is what my dealer told me.
Old 14-06-06, 08:43 PM   #6
Lissa
Just Ballast
Lissa's Avatar
Another stupid piece of EU legislation. Thank God we've got a curvy and can CHOOSE when our lights are necessary!
Old 14-06-06, 09:19 PM   #7
The Basket
Don't see lights-on as problem.
Makes you more visible. No bad thing that.
Old 14-06-06, 09:21 PM   #8
I'm not certain that's - as yet anyway - correct.
We now get bikes that are as similar as possible for manufacturing reasons - and the makers are anticipating impending legislation, but as far as I'm aware our legislation doesn't as yet require daytime lights to be used or fitted.
Not 100% about this though, so I reserve my democratic right to be as wrong as I usually am.
Old 14-06-06, 09:40 PM   #9
Stu
Trinity
Stu's Avatar
Can this really be worth it?
I'm with the Basket on this.
Old 14-06-06, 09:48 PM   #10
Villers
True and I would normally agree. I work on a licenced site of a certain variety that is a national security issue, with a certain material that is very sensitive. As part of my going to work routine I have to enter through a gate with armed guards and show a pass that belongs to the government. At the gate (especially in winter) there is a big sign that says 'please turn off your headlights' and if you are forgetful enough you get a right bollocking and the poor copper gets blinded. How do I take my bike to work in winter, and everytime the poor sod is trying to get the yellow blobs out of his eyes, and apologise for my lights being on all the time. 'Sorry mate its EU legislation'. Im guessing eventually I will have a black stripe on my pass that means I cant come onto site in a vehicle.
Disable paypass? tigersaw Idle Banter 5 27-10-08 08:30 AM
Headlights Only light up with passing switch Binky800 SV Talk, Tuning & Tweaking 11 02-07-08 06:56 PM
difference between models..sy,, sx,,, bla bla stooster SV Talk, Tuning & Tweaking 15 20-02-07 01:20 PM
parking lights disable? redeye-dv SV Talk, Tuning & Tweaking 16 12-01-07 12:16 AM
differences between K3 and K4 models - help! benny SV Talk, Tuning & Tweaking 4 14-03-05 11:33 AM
