The Essex Lounge No Nova's or Impreza's alllowed. Your MC's are Supervox & Messie.
Old 14-06-06, 02:38 PM   #1
SpankyHam
Default Carb Balancing Anyone know how to / have the equippment?
As above, can anyone help me balancing the carbs ?
Old 14-06-06, 02:50 PM   #2
Scoobs
'tis a piece of ****, but can be fiddly. Need to attach the gauges to the vacuum take off on the carbs. The back one is easy to access. The front one is a bleedin knuckle nightmare.
Once the gauges are attached, start the bike a level the dials using the screw on the arm that connects the two butterflies. It doesn't matter what the gauges are reading as long as they are level. Morgan Carbtune is the gauge to get and generally gets the nod as one of the best home kit gauges. Avoid dial gauges if possible.
Old 14-06-06, 03:08 PM   #3
Ping
I used to have the equipment, well it's stu's but i suspect he took it when he left.
sorry
if he hasn't taken it then u can borrow it.. it's for an il4 but can probably just use 2 of the gauages...
Old 14-06-06, 11:02 PM   #4
ArtyLady
Default Re: Carb Balancing Anyone know how to / have the equippment?
yeah - its easy - undo the bogglebibbler, then pull of the dynominger, stick the flunger in the diggle and wiggle the dobble about for 3 seconds - there all done
I dont bloody know I just ride the thing
well soon anyway
Old 15-06-06, 06:47 AM   #5
Scoobs
You forgot about releasing the widger, unwinding the flange rotator and fine adjusting the minge gimlet.
You don't bloody say.
Old 15-06-06, 07:27 AM   #6
pegasus
pegasus's Avatar
well soon anyway
hahahahhaha what a word.........sounds like a girl i used to date
tune in, turn on, burn out
pegasus is offline   Reply With Quote
Old 15-06-06, 08:16 AM   #7
ArtyLady
Oooooeerrrr Scoobs ............... I'll wiggle the dobble while you fine adjust the minge gimlet
Old 15-06-06, 08:19 AM   #8
ArtyLady
well soon anyway
Old 15-06-06, 08:49 AM   #9
Scoobs
Saucepot!
Old 15-06-06, 11:11 AM   #10
ArtyLady
Saucepot!
Oh yes - even at my age !
Carb balancing Grinch Soho Massive 10 07-05-09 07:44 AM
Carb balancing. scottjames SV Talk, Tuning & Tweaking 12 27-10-08 01:14 PM
carb balancing ricky SELKENT 6 22-04-08 08:11 AM
Carb balancing by ear? ikb SV Talk, Tuning & Tweaking 16 31-01-08 12:28 PM
carb balancing johndo SV Talk, Tuning & Tweaking 3 08-04-05 05:31 PM
