Hi, Anyone fitted an original bellypan to a K3 ?. I bought one without fitting instructions and want to ensure I am bolting it to the correct position.
Cheers |
Easy if you have the 3 mounting brackets
One onto the oil radiator (remove the spacers inside the rubber washers) one each side - they are different fittings for each side offer it up and it should all be apparent where it goes have a look on the Ron Ayres fiche and you'll be able to see an exploded diagram which more or less shows what goes where have a look in the manual for the torque setting needed for the bolts when you come to tighten them - manuals are in the FAQ section on the main site |
Belly Pan? I've done this. Easy,But you do NEED to re-torque the Nuts and Bolts.
I didn't have to touch the Oil cooler on mine! ![]() I will get the torque settings,maybe able to scan the instructions and email them later if you like?! ![]() |
I should be able to email the full instructions to you,with pics of what you should have with it!
Let me know,(had a right mare trying to sort it out for you! ![]() |
Bellypan fitting, question | thefallenangel | SV Talk, Tuning & Tweaking | 6 | 24-12-08 03:03 PM |
curvy bellypan fitting kit | husky03 | Stuff Wanted | 0 | 30-01-08 06:26 PM |
Fitting Original Lowers | Cam_73 | SV Talk, Tuning & Tweaking | 2 | 18-07-07 10:05 AM |
original suzuki lowers before & after | hovis | Photos | 20 | 08-12-06 12:18 PM |
Plastic Pyramids bellypan for the original | northwind | Bodywork | 0 | 18-07-04 11:21 PM |
