Old 19-06-06, 07:20 PM   #1
Red ones
Red ones's Avatar
Default Do you remember this guy?
BMW accelerator stuck?
He has been arrested Found out at last!
Old 19-06-06, 07:29 PM   #2
Iansv
I did have to laugh when I read that earlier... Just glad he didn't take anyone else out
Old 19-06-06, 08:59 PM   #3
Speedy
Yeah nice try mate!
I might try that when on my bike........."Yes occifer,my hand got stuck!"
Old 19-06-06, 09:21 PM   #4
embee
embee's Avatar
Yeah, you would think that a major manufacturer like BMW would install some sort of override device in case of such an event, maybe they could call it an ignition key.
Old 19-06-06, 09:38 PM   #5
Speedy
PMSL!!!!!
Old 19-06-06, 09:43 PM   #6
jenni
PMSL!!!!!
lol, i'm dumb.....i didn't think of that
Old 19-06-06, 09:44 PM   #7
Cronos
Ask yourself this. How many times have you heard of a vehicle with an intermittent fault that's not being spotted or rectified by the main dealer network?
As for the ignition key, well a number of years ago my mother had a 406 which had a mind of it's own. It would start on it's own (without the keys in the ignition) for no reason at all! The main dealer took a year to acknowledge the fault and even then couldn't identify or correct it.
Old 19-06-06, 09:49 PM   #8
ArtyLady
But if he did it deliberately why on earth would he be phoning the emergency services for help?
Old 19-06-06, 09:58 PM   #9
Speedy
MOST cars these days are fitted with a switch on the brake pedal that not only activates the Brake lights,but also tells the Engine management system that the driver is braking.
The ECU then basically aknowledges this.
IF the throttle is open at this point the ECU,after a pre-determined time period,WILL cut either the Fuel or the Ignition system to the engine.
This system has been installed because alot of cars now use 'Fly-by-Wire' technology,and if it goes wrong there is no mechanical link between the pedal and throttle valve/injection system.
SO
If the guy had hit the brakes,this,I would think,would have solved his problem.
Or he could have switched the Ignition off.
Muppet.
Old 19-06-06, 11:42 PM   #10
Peter Henry
Daimo would fight the case to the death! :P :P :P
Remember Remember the 5th of September fizzwheel Idle Banter 45 08-09-08 01:11 PM
Always remember to look where your going! dizzyblonde Bikes - Talk & Issues 8 26-05-08 11:32 PM
Remember this... fizzwheel Idle Banter 1 19-12-07 08:21 AM
I can't remember his name????? smillsy Soho Massive 9 09-06-07 08:43 AM
Do you remember . . . . . Rossi_C Soho Massive 16 23-12-06 09:13 PM
