Old 26-06-06, 08:29 PM   #1
goof
Default Brake probs (with pictures!)
Covered this on a thread with Scoobs the other night, just adding pics into the mix!
Put on new pads but for some reason the caliper housing seems to stick out as much as the pad (shown with 1 & 2 ) - #1 also had a clip on it to hold the inner pad in place but I removed this to see if I could get any joy. As you can see I didn't, it's contacting with the disc
Old 26-06-06, 10:20 PM   #2
goof
Thanks for the input but I don't see how it can be anything to do with the forks when I can see that the brake housing (#1 & 2) exceeds the line of the pad when it's off.
Old 27-06-06, 12:29 AM   #3
Blue Flame
Blue Flame's Avatar
No offence but have you fitted them the right way round. IE have you tried to put the left caliper pads on the right caliper and vice versa. !!!
Triumph Sprint GT 1050 -Sexy Phantom Black; Powerbronze Screen
Previous >> K3 SV650S - Candy Copper;Lower Fairing Set;Fender Extender; Powerbronze Screen; HEL Braided Lines;
Blue Flame is offline   Reply With Quote
Old 27-06-06, 12:58 AM   #4
Itching 2 go
TBH I cant really see what you are saying.
Have you pushed the pistons back in properly?
have you pushed the sliding bracked back properly?
Old 27-06-06, 09:19 AM   #5
I can't figure it from the pics... The gap with the pads looks wrong to me, but I can't figure out why. Sorry, not much help! If you want a second opinuionj I can probably fire over one night this week...
Old 27-06-06, 11:32 AM   #6
goof
Thanks for the replies.
Blue - pads deffo on right, they only go on one way!
Itching - this may be the problem, my initial set had metal clips on the rear. I assumed these were just because they were a different type of pad but it looks like clips should've been transferred?
Sid - not sure tbh
North - thanks mate, decent of you as ever
Will wait and see if these clips will sort it though.
Old 27-06-06, 11:54 AM   #7
instigator
Fitted the wheel correctly? I had this exact same problem. I took the wheel of and put it back on and tightened the axle bolt right up. It went in further than last time I remembered. Perhaps only maybe 4mm more but this stopped that part of the caliper hitting the disc.
Wheel ain't fitted properly is my educated guess.
Apparently it happens quite often.
Old 27-06-06, 12:06 PM   #8
goof
Thanks Instigator, looks like it's back to the drawing board on that then.
Does anyone know about these pad backing clips? Have they to be transferred?
Old 27-06-06, 12:15 PM   #9
TSM
The Sick Man
TSM's Avatar
They are less than 1mm thick so would unlikely make a huge diffrence, check the way the wheel is fitted as this is the most likley soloution.
Old 27-06-06, 03:14 PM   #10
goof
Thanks TSM and Sid, will get the front end off then and sort it. Also got new brake seals and fluid today so should be good to go (though no ruber grease was provided with seals, bloke in shop said I didn't need any ).
Brake light probs Baz SV Talk, Tuning & Tweaking 9 24-09-08 08:07 AM
reg rec probs maybe dizzyblonde SV Talk, Tuning & Tweaking 4 27-09-07 04:07 PM
more probs hovis Idle Banter 6 02-10-06 09:05 AM
Front brake probs, advice needed. Dirty Baz SV Talk, Tuning & Tweaking 14 21-03-05 04:18 PM
sticking brake pt 2 (got some lovely pictures ) *update* Warren SV Talk, Tuning & Tweaking 18 24-01-05 04:59 PM
