Old 11-07-06, 11:32 AM   #1
cuffy
Default Which chain?
Need new chain n spocket set, what are peoples preference? "O" ring or "X" ring is there much difference?
Thanx in advance.
Old 11-07-06, 11:42 AM   #2
andyaikido
O-ring will be fine but i got a gold X-ring type hoping to get a bit more life out it (and because i'm a tart).
Old 11-07-06, 11:42 AM   #3
timwilky
timwilky's Avatar
My opinion is that an SV does not justify the extra cost of an X ring chain. Get a good value set such as Triple S chain with JT Sprockets, You should be able to do it for about 70 notes.
Not Grumpy, opinionated.
Old 11-07-06, 11:42 AM   #4
Carsick
Technically speaking, x-ring will hold the oil in the seals better, but I haven't seen or heard of any benefits from using them.
Old 11-07-06, 11:50 AM   #5
jonboy
I've had an Iris Gold x-ring and it was nowhere near as good as the stock Suzuki o-ring. Get a cheapish o-ring from a reputable manufacturer and just keep it lubed and well maintained.
Old 11-07-06, 06:06 PM   #6
Paws
Ive got a gold x ring, they last longer and look better.
Old 11-07-06, 06:16 PM   #7
Biker Biggles
Biker Biggles's Avatar
Can't fault Suzuki OEM chain and sprockets.Forget the tarty ones and get a chain oiler.Last forever.
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
Cam Chain jambo Stuff Wanted 6 05-08-08 10:28 AM
Chain on the way out? krhall SV Talk, Tuning & Tweaking 5 20-04-08 07:14 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
