Old 17-07-06, 08:24 PM   #1
svrash
Default Rear brake questions
Are most suzuki master cylinders the same as the curvey SV's?
I've never had enough power in my rear brake, not even enough to make it skid So i'm thinking of overhauling but can't afford the time the bikes off the road so i'm on the look out for a second hand one
Old 17-07-06, 08:28 PM   #2
Tris
I felt that about mine
A good lubing and fettling of the rear caliper sorted it
Might be worth a go
Tris
Old 17-07-06, 08:29 PM   #3
lukemillar
Default Re: Rear brake master cylinder
Originally Posted by svrash
I've never had enough power in my rear brake, not even enough to make it skid :
Really!? I have no problems getting my rear to lock (under control of course!) and that was completly stock - pads, lines and original fluid. Are you sure checking the pads and giving it a good clean and bleed wouldn't sort it out?
Old 17-07-06, 08:50 PM   #4
Viney
Possibly a siezed, or poor working rear caliper
Old 17-07-06, 08:54 PM   #5
Carsick
Sounds bloody likely to me.
I know for a fact that I've got air in mine and it'll still happily lock the rear wheel.
The master cylinders seem to be the same as the K series GSXR, so I suspect that most are the same.
Old 17-07-06, 10:26 PM   #6
svrash
over hauled the caliper twice (with new seals), clean it regularly, got HH pads and a new(ish) wavey disc, new stainless braided line and obviously fresh fluid which I've bleed 3-4 times (through my stainless nipples) which only really leaves one other component before i ditch the caliper for another
EDIT: So what model suzuki calipers will fit?
Old 17-07-06, 10:44 PM   #7
rictus01
rictus01's Avatar
given the disc suface is good, the pads are beded in, the hose is sound and the caliper has been properly overhauled, it leaved two possibilities, the first is your master cylinder seals have gone or you're having problems bleeding the system.
Whilst the first is possible it's not a normal ware point and easily checked when bleeding the brakes, the second however I've had many cases of people having bled their brakes several times, but still unable to do it properly, after being shown, they have been able to solve a problem they thought was something else.
Just for ref, my 02 never had a problem with the rear master cylinder or caliper, in fact I had a braided rear line but never needed to fit it, good wash down thoughout winter and didn't even need a rebuild for it's 154,000 mile life (currently on my brothers SV for the last 8,000 miles).
Cheers Mark.
Old 18-07-06, 08:43 AM   #8
kciN
Cheers Mark.
Really? sh*t!!
Oh yeah, Mine locks up fine, so perhaps a complete overhaul/bleed??
Old 20-07-06, 11:47 AM   #9
Sir Trev
Sir Trev's Avatar
Sure your pads are OK? My rear brake is hopeless but from the splatters over the disc hanger I'd say I over lubed the chain last time and I've probably wrecked the pads.
Old 20-07-06, 12:21 PM   #10
jonboy
I've always found the rear brake on the SV to be first class, and the wheel can be locked very easily. So as others have said, there's got to be a fault somewhere.
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
Brake Bleeding - Two Questions Colboy SV Talk, Tuning & Tweaking 16 24-01-07 10:04 PM
More Brake questions. What fluid? Diveboy SV Talk, Tuning & Tweaking 3 10-04-06 05:21 PM
Yet more brake line questions (newbie). Blindly SV Talk, Tuning & Tweaking 5 03-04-06 10:06 AM
