Old 19-07-06, 12:40 PM   #1
red5
Default Bikes gone mad, help needed
Hello,
Whilst riding home this lunch my bike started behaving strange, the speedo and rev counter started jumping up and down, then my fuel light flashed on then off, then came on warning me I'm low (I'm not) then when I indicated it flashed too quickly.
Got to my house sat there and the needles on the speedo and rev counter were jumping about, dash lights flashing on and off etc and before I got to my house the engine would't fire properly.
Anyone know what this is, it is as though something is shorting out but what would make all the dash dials go mad and the engine misfire....only a short trip, about 10mins from work.
I did install a ZX10R shock yesterday and with the usual battery problems I have spaced mine back but it is touching the shock reservoir and I've noticed now it's pushed in against the battery case, but not breached it.
If the battery was dying the engine should still fire though?, could I have damaged the battery and lowered the voltage going through my electrics causing it?.
Any help greatly received.
Old 19-07-06, 12:46 PM   #2
Check all the wiring you have disturbed for loose connections or shorts, could be anything.
If the battery case isn't breached then it won't be that, but make sure that it's not chafing on anything that'll eventually wear through it, not only will the battery be buggered but your bike won't thank for the bath in battery acid.
Old 19-07-06, 01:06 PM   #3
Get it exorcised first
I had some of those symptoms just from a loose battery terminal, seems that the gauges etc are sensitive to that sort of thing.
Old 19-07-06, 01:31 PM   #4
red5
I'll check it over tonight, damn thing is possessed at the moment, annoying me as the shock seems to be much better and now I can't ride the damn thing.
Old 19-07-06, 07:14 PM   #5
xrphil
if its effected the voltage by damage this can cause problems with engine management / cdi etc.
had it a few years ago on a kawa turbo, altinator was buggered (in germany )
Old 20-07-06, 04:24 PM   #6
squirrel_hunter
squirrel_hunter's Avatar
Same here, check that first. Hopefully you'll be lucky and haven't fryed the reg/rec as I did
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Advice needed - 125cc bikes missrubberduckofdeath Bikes - Talk & Issues 144 01-04-08 10:34 AM
My New Bikes Fearg Bikes - Talk & Issues 9 22-12-07 02:32 PM
Bikes on the Brain - Psychologist Needed!! Demonz Idle Banter 18 06-01-07 12:58 AM
44 bikes needed for a giant ArtAttack Viney Rideouts & Meetings 82 21-09-06 03:32 PM
Sat nav for bikes tinpants Bikes - Talk & Issues 31 17-09-06 09:04 PM
