Old 27-07-06, 11:18 AM   #1
MR K
Default Pins & Needles in Hands
Hi Folks,
Bit random but hoping you can help. Over the last few days, I have noticed that I am getting pins and needles in my hands when riding. Can this be from gripping too hard or from a bad wrist angle? I can usually get rid of it by just shaking my hands out at lights but I'm getting worried I might be doing something serious.
Anyone else experienced this or something similar?
Old 27-07-06, 11:21 AM   #2
DanAbnormal
Seems quite common on the SV mate. I used to get it when I first had my SV but it wore off eventually.
Dan
Old 27-07-06, 11:22 AM   #3
andyaikido
I get this too but after a long time on constant throttle (motrway treks). Try taking a bit of weight off your wrists by gripping the tank with your knees or resting your chest on the tank. Of course this means you now get sore thighs/back or a stiff neck so you have to keep swapping between positions.
Old 27-07-06, 11:24 AM   #4
TSM
The Sick Man
TSM's Avatar
Have you got bar end wights (steel ones)?
Balenced the carbs recenty?
Old 27-07-06, 11:26 AM   #5
Ed
Don't hold on too tight. Also, keep the blood flowing by moving your fingers around.
Old 27-07-06, 11:45 AM   #6
Kilted Ginger
Eat bananas potassium does something that prevents cramps, numbness, so I've been told, (someone medical will probably shoot me down )
Old 27-07-06, 12:12 PM   #7
DanDare
Yeah I get it too, also right hand goes numb after a while so I rest my fingers on the brake lever.
Old 27-07-06, 12:21 PM   #8
Abyss
I get it some days but not others... Got it today for the 1st time this week.
Old 27-07-06, 05:12 PM   #9
fizzwheel
fizzwheel's Avatar
Undo the the clutch and brake levers and rotate them round the bars. Somewhere out there is an article that tells you the right angle to set them at.
I've got mine set so I have a straight line from my elbow, through my wrist. It really does make a difference.
Also as others have said try and relax your grip on the bars. Fitting heavier bar end weights may or may not help.
HTH.
Old 27-07-06, 05:32 PM   #10
socommk23
i had this once after doing the a34 at a constant 80mph....hurt like hell!
but shook it off.
just relax more and take hands off bars quickly every now and then....pref not both at same time.
Cramping and pins/ needles Specialone Bikes - Talk & Issues 27 06-05-09 12:17 AM
Pins and Needles! COLZO Idle Banter 13 08-01-09 08:08 AM
Adjustable needles mwr2452 SV Talk, Tuning & Tweaking 9 07-07-07 08:05 PM
Adjusting carb needles Fuzz SV Talk, Tuning & Tweaking 16 05-09-05 08:15 AM
Shim the Carbs Needles TSM SV Talk, Tuning & Tweaking 3 25-07-05 11:26 AM
