Old 01-08-06, 07:37 AM   #1
glade
glade's Avatar
Default Quick Torque Wrench Q
Want to buy a torque wrench ASAP so i can adjust my chain.
(Wether online or at halfords this evening)
Have looked up the rear axle nut torque (100Nm)
2 questions
1) What size socket do i need for the rear axle nut
2) What torque range should i look for to be useful for other jobs
seen this on google, would this sort of thing be up to the job? £6.53 sounds too cheap for a decent tool!
Draper 3001A 1/2" Square Drive Torque Wrench 30-210Nm - £6.53
Many Thanks!
glade is offline   Reply With Quote
Old 01-08-06, 08:10 AM   #2
lukemillar
I bought 1 that went from 12 - 68 nm. Had a look through the service books, and that seemed to cover most things except the really tight stuff, so I'm going to have to buy a second. I couldn't find a torque wrench that would cover the entire range I needed. I bought a Britool one off eBay for about 30 pounds - I rather have a decent second hand one than a not-so-great new one for the same money!
Old 01-08-06, 08:58 AM   #3
glade
glade's Avatar
25mm Nut on rear axle
Old 01-08-06, 09:00 AM   #4
Carsick
It's a good idea to have one to hand, but in the short term, you can borrow mine if you want.
Old 01-08-06, 09:01 AM   #5
Stu
Trinity
Stu's Avatar
Sorry, don't know what they are - just look in your tool kit- but the 2 sides are different.
Thought a torque wrench took a variety of heads.
Old 01-08-06, 09:23 AM   #6
Accuracy's most important in low ranges, it doesn't matter much at all if a 100nm bolt is out by a couple of nm on either side- that Draper should do you just fine for big values, and get a better low value one if you plan to do a lot of work. The Halfords ones aren't bad at all.
Old 01-08-06, 09:24 AM   #7
simple simon
I think if you look at the link you mentioned from google, you will find the £6.53 is for a repair kit, not the wrench!
Have a look here for the best prices I found for Draper tools
http://www.tool-catalogue.co.uk/tool...roducts_id/640
Old 01-08-06, 09:28 AM   #8
Ah, that makes sense Machine Mart do a reasonably good high-value 1/2 inch socket-drive torque wrench for around a tenner.
Old 01-08-06, 09:36 AM   #9
Carsick
I've got the one from MM.
Old 01-08-06, 10:38 AM   #10
glade
glade's Avatar
Oops i didnt really look into that one.
Cheers Carsick - I've sent a PM!
Will get the big torque wrench first i think for doing the chain, then buy a smaller more accurate one later when i need to to other bits.
Torque Wrench Splosh Bikes - Talk & Issues 22 11-01-08 08:41 AM
Torque wrench Kilted Ginger SV Ecosse 6 16-11-06 10:05 PM
Torque Wrench andyb SV Talk, Tuning & Tweaking 13 16-02-06 10:43 PM
Which torque wrench ?? pepe SV Talk, Tuning & Tweaking 9 06-05-05 07:48 AM
Torque Wrench TSM SV Talk, Tuning & Tweaking 21 28-04-05 09:06 AM
