Old 06-08-06, 08:28 PM   #1
Stu
Trinity
Stu's Avatar
Default The devil himself visited at my door!
Riding my SV with the stock can cut off!
Awesome!
Getting the neighbours used to my new Blue Flame
Old 06-08-06, 08:37 PM   #2
TSM
The Sick Man
TSM's Avatar
Yep but it can aparently damage your engine.
Old 06-08-06, 09:46 PM   #3
Stu
Trinity
Stu's Avatar
really, so I can't do it again or go for a ride?
The BF's not secured yet.
Another point I would like to remove the foot pegs to positon the can exactly where I want it. Is there anywhere I can get a bracket made up to attach the strap to the foot peg mounting points.
Presumably I can't get away without a strap hanger?
Old 06-08-06, 09:57 PM   #4
Definately don't try it without a hanger... Any can would be tested by that (Ask Saint Matt) but Blue Flame like to fall apart even with a secure strap, never mind without. I wouldn't even do it for a mile, if I were you.
Your best bet for a custom hanger would be to work out what you want and make a template using, ideally, thin steel- including the bends at both ends. Then, depending on what you want it to look like, speak to a welder or bike fabricator (Streetfighters would be a good port of call here, I like Izax of Newton myself but there's a hundred shops that could do it)
The reason you want to use something like thin steel to do the template is that the angles at the ends will be critical- you could use cardboard but it'd flatten out.
Old 06-08-06, 10:15 PM   #5
DanAbnormal
Yeah running it without a can can damage exhaust valves apparently. Sounds like a Harley too, which is a bad thing!
Old 07-08-06, 08:10 AM   #6
thor
My bike sounded the same with or without the can... says a lot about the can doesn't it!
Old 07-08-06, 10:10 AM   #7
I rode my Virago with no front header for a while Sounded like POOONKffffft POOOONKffft. Awful, just awful. Probably did damage the valves, but then that was the only part of the bike that wasn't already rusty or held on with tape so it didn't really make any difference.
Old 07-08-06, 10:36 AM   #8
Stu
Trinity
Stu's Avatar
Can I get someone to cut, shorten and weld the original footpeg hanger?
Old 07-08-06, 10:49 AM   #9
If your pockets are deep enough you can do anything But, what might be better is to grind off the can hanger part of the footpeg, then get a bit of flat ally- 5mm maybe- and make a bracket out of that, and bolt it between the bracket and subframe? I was kind of working on the assumption that you wanted to dispense with the pillion pegs.
I reckon part of Blueflame's bad rep for falling apart is that their bracket's really far forward and the can's long (and fairly heavy at the tail end, too, if you get a twinport) which makes it more susceptible to vibration. So if you can move the strap back up the can, that might help.
Old 07-08-06, 07:51 PM   #10
andyaikido
I found that too. Mildy disappointed when I ran without a can, was expecting it to sound obscenely loud.
Visited my new dog Exupdog Idle Banter 29 14-01-09 12:03 AM
Pictures from the Lake District Ride out !!!what nice places we visited!!! gecco The Essex Lounge 13 01-10-08 07:37 AM
Visited Evotech today :D G Photos 17 22-06-08 07:55 AM
Anyone visited the Millau Viaduct in France yet??? UMA EuroTour 8 21-06-06 02:52 PM
