Old 23-08-06, 04:23 PM   #1
TSM
The Sick Man
TSM's Avatar
Default Click Click Click Under Braking
I have now have a worreing noise comming from the front brakes/wheel. Under braking i now get a click click click (speed related) noise which is transfered through the bars. It only happens when i apply the brakes. Its a new noise aside from the warped disks buzz. Just is it related to the brakes or possably the wheel bearings, all is fine if im not on the brakes though.
Not a major worrey as i will have some replacement disks next week that are not warped or loose fitting bobins.
Old 23-08-06, 04:31 PM   #2
SDMF
i've been having his same noise for about 2 weeks now ( since dropping the bike after walking away from it without the sidestand down) . It only seems to happen though under heavy (emergency-stop type)) braking. I think that it's originating from the calipers, though not 100% certain.
Old 23-08-06, 04:32 PM   #3
TSM
The Sick Man
TSM's Avatar
Ive got a diffrent front end (SRAD 600), diff wheel/forks/disks/brakes. So for me i doubt the calipers.
Old 23-08-06, 10:10 PM   #4
svrash
I think its the loose pads mate, i get the same on mine, especially when i hit a bump while braking
I think the way to solve all the GSXR front end rattles would be to leave the SV front end on but there's no fun in that
Mine brakes have started squeeking, i think i might have some dirt in between the washers spacing the calipers out
Old 23-08-06, 10:12 PM   #5
TSM
The Sick Man
TSM's Avatar
I think to solve all the GSXR front end probs would be to leave the SV front end on but there's no fun in that
I changed them recently and the clunk that was comming from the pads went and left the clunk from the disks (being changed next week hopefully). This noise is something diffrent.
ps. Why have you got washers spacing the calipers out, are you running the later K2+ calipers?
Old 23-08-06, 10:20 PM   #6
svrash
Oh yeah!! and K2 USD forks
Old 26-08-06, 06:23 PM   #7
TLMark
TLMark's Avatar
Could be the disc buttons worn check to see if the discs are loose in the same direction as wheel movement I had this on my old gixxer
Got a TL1000s an a SV650, Ducati 1098S and Monster 1100Evo
VTwins Rule
TLMark is offline   Reply With Quote
One click a day!Just like an apple! TOLAROS Idle Banter 10 23-02-09 01:54 PM
Scooter enthusiasts click here......... jumjum_0214 Idle Banter 4 21-04-08 08:53 AM
click keithd Idle Banter 9 10-03-08 01:30 PM
click here pegasus The Essex Lounge 1 02-01-07 08:25 PM
click, click from front brakes triumph5ta SV Talk, Tuning & Tweaking 14 18-07-06 10:19 AM
