Old 26-08-06, 06:22 AM   #1
Yellow650
Default Chain Lube Question
I'm sure this has been asked before, but how often do you guys lube your chains? I do it about every 200 or 300 miles.
Old 26-08-06, 07:00 AM   #2
Davido
I do it every week or so. Or just whenever I feel guilty that its so unclean.
I'm using putoline spray on stuff atm which seems to work quite well. Just give it a quick spray and leave it to do its job overnight.
Cheers.
Old 26-08-06, 10:34 AM   #3
Razor
Never, my scottoiler does it for me
Old 26-08-06, 05:21 PM   #4
adburn
i use a scottolier, but my brother just gives his a squirt of wd40 every day - he covers the whole bike in it before he goes out - engine, forks, frame, and chain is that bad? I followed him along our street last week and i thought his bike had caugh fire - but it was just the WD40 smoking as his engine and can got hot.
Old 26-08-06, 05:28 PM   #5
Razor
WD40 is too light for chain lube. I use it to clean and degrease my chain.
Old 26-08-06, 05:33 PM   #6
Lissa
Just Ballast
Lissa's Avatar
Got a scottoiler fitted now, but before that used to lube after every ride while the chain was still warm with a light lube.
Old 27-08-06, 01:26 PM   #7
RandyO
I use automatic transmission fluid (dextron III) in my scottoiler
Old 27-08-06, 02:33 PM   #8
i apply alittle amount often to save it getting flung all over the bike.
Old 27-08-06, 04:22 PM   #9
Tim in Belgium
A bit of spray lube after a long ride, or when I remember. I always check before going out that the chain doesn't look dry, seems to have worked fine so far as very little chain stretch.
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
How often do you lube the chain? Binky SV Talk, Tuning & Tweaking 27 11-08-08 03:56 PM
Chain Lube jonhunt Bikes - Talk & Issues 7 15-04-07 09:38 PM
Chain lube TC3 Bikes - Talk & Issues 7 02-09-05 02:24 PM
Chain Lube fred_dillon SV Talk, Tuning & Tweaking 12 25-05-05 08:30 PM
