I recently made a chain lube topic, and saw that some people use wd-40 or a combination of a scottoiler and wd-40. I just wanted to let people know (or remind, perhaps) that wd-40 is a SOLVENT, not a lubricant. It will clean things quite well, but after that it acts more like a degreaser than a lubricant.
Preaching to the choir Yellow.
Ditto. For more detailed explanation of why it isnt a good lubricant are:
> Its not very viscous! It wont act like a "barrier" between moving parts in the same way a thicker, dedicated chain lube will. > Volatility! It will evaporate quite easily, even at moderate tempuratures. With the chain moving, generating heat, the WD-40 will be gone in no time Matt P.S correct me if I'm wrong, but this is what i have observed! |
I actually use to WD40 to clean my chain, before applying some proper chain gog. (having first made sure all the WD40 is cleaned off also).
WD-40 is ACE and you all know why
#6 | |
#7 | ||
#8 | |
![]() ![]() ![]() Kwak - Have you seen the new "smart straw" cans ? bit more expensive but very good ![]() http://www.wd40.com/Brands/wd40_smart_straw.html |
#9 | ||
#10 |
My dad makes me spray the end can, the engine casing, the forks, the swingarm and the down pipe with it every time i wash it. I go through a lot of wd40. But he loves it. An actual addict.
