So when I think back to my DAS course back in June I don't remember any advice on going fast round bends or being smooth. I guess much like with a car, you learn it all yourself on the roads. However, unlike in a car, you're more likely to die if you get it wrong!
![]() So I'd just like to gather some opinion and tips on the things they don't tell you in your training? Is the key to cornering all about where you look? I've felt a slight improvement this weekend as I've leaned a bit more and looked ahead rather than at the road just in front of me but I'm still struggling with throttle smoothness round 90 deg (and tighter) turns. I'm wondering if I'm taking corners in too low a gear due to my fear of being too fast and pushing wide? Do people slip the clutch and drag the back brake on such turns or just barrel round in gear? I realise it depends on the turn but general advice is good. I'm mainly talking about urban riding, T junctions etc... Secondly - I'm a big chap (if I were a rugby player I'd be a prop) and I'm struggling with wind buffeting above, shall we say, the legal limit. I can't really tuck in anymore without feeling like I'm losing visibility. Is a double bubble screen the answer? I can also see **** all in my RH wing mirror (just to re-enforce my size problem). Worth getting some kind of extension device? |
The DAS course really only qualifies you to ride down the road and turn left/right without killing yourself. You really need to gain some more experience, both theory and practice, either by talking to more skilled riders, or taking some more advanced training (or both)
yep i think uve got it ,look at where you want to b NOT THE ROAD /GRASS VERGE /PAVEMENT/FRONT WHEEL ,re brake if i think im going in a wee bit too fast then ill scrub off speed with the rear,i find this settles the bike ,and dont go round a bend using an open/shut /open throttle this causes all sorts of running wide /changing ur line etc.if you go down a gear and hold a steady throttle round and ease on the gas when u can see itll b much btr .theres been some good posts about this ,but more than anything else its milage/practice you need
and re mirrors -get extenders from chewy ,they will make a big diff ![]() |
Road positioning is also key to getting round corners.
Again grecian9, we're probably pretty much similar in ability. It was only after spending a good few hours riding (both on a track and countryside riding) that I felt a lot better about corners.
General advice, I stick to a lower gear and hate cornering in 6th. This way, if I'm coming in too hot for a corner, engine braking is the answer. Hanging off the bike a little helps too, more so the upper body than the lower body. A tip I picked up on here was to use your outside arm against the side of the tank like an anchor, then try to just let it all hang loose. At first, I felt like I was having to hold the bike up for fear of binning it. Now it feels more like the bike is holding me up. I may be wrong, but DON'T slip the clutch going around corners (unless it's very slow speed T-junctions etc). This removes the engine's force acting on the rear end, and could lead to some sticky situations (my first off - on my CG - was like this, pulled the clutch and the front brake going round a right with an off camber ![]() Counter-steering helps a lot as well, especially three figure speeds on my private runway. Just remember, the bike will generally lean over more than you think & still keep grip (unless you're wondering how far over you can go whilst sliding the bike on it's side)! I reckon you should be trying to look at the vanishing point (place where left kerb meets right, if there are any kerbs). Target fixation was a big problem of mine until the time on the track. This will also help you to read just how tight the corner will be, and if it's tightening or opening. The latter means hard on the gas ![]() Since you're a 'big fella' I reckon a double bubble could be the way to go. I intend on doing the same to mine, but more for an MPG reason than a comfort reason. I'll get around to it when finances & time permit. About the mirrors, I don't know if it'll help, but I can see my arms in my mirrors. About 1/3 of the mirror is actually my arm. This leads to a huge blind spot right behind me. The cheap solution I've found is to simply tuck my elbows in. Let me know if you have any better fairing with an extension. ![]() |
#6 | ||||
Hi mate,
It took me a while and a Bikesafe weekend to get a bit more confident, especially in the wet. Quote:
![]() The other advice is "slow in, quicker out". Works on two levels; firstly you a less likely to get caught out having misjudged a bend and, secondly, by driving round the bend you have unloaded the front tyre a bit, meaning that it's less likely to run wide or lose grip. I read somewhere that the ideal weight balance is something like 40:60 as front:rear. Quote:
![]() You should always be able to stop on your side of the road within the distance that you can see to be clear. Period. If you meant "Do you just ride round, no brake and ano clutch slip?" then I can't answer you. Every bike and every corner is different. You will find your own best way given time and experience ![]() HTH a little. |
#7 | |
What really helped me round the corners was to really grip like a limpet with the legs and NOT put ANY weight on the bars - it makes them twitchy. Just tighten up, and as Baph said, really gentle inputs. The leaning on the bars thing was my biggest breakthrough when I was learning to ride, and they said nothing in DAS! Re jumpy acceleration in bends, is your chain adjusted properly? Too loose and it can snatch, which makes it fdeel as though the throttle is uneven. |
#8 | ||
![]() Mind you, it's probably not the time spent on a bike that matters much, more the mileage. I've done just shy of 1500 miles in the last 19 days, almost all in countryside twisties, with a little motorway, very little town (unless I have to), and a morning zipping around a track ![]() |
#9 | |||
What IMHO you dont want to be doing is come hairing up to a corner. Snap the throttle shut and then grab a big handful of brake. All this does is unsettle the front suspension which means the front / rear ends of the bike don't work as well. If you can be more gentle and gradual with your inputs. You'll give the suspension more time to cope with the weight transfer from braking / accelerating, which means your feel for what the bike is doing will be better and also you are allowing the tyres to grip the road as best they can. I wouldnt worry about hanging off / knee down techniques to start with. Just concentrate on road position, speed and being in the correct gear and being smooth with the throttle and brakes and give yourself time to read the road ahead. Quote:
If your finding you need to slip the clutch to get turned into a T-junction or a sharp corner you may find that your actually in to high a gear. Quote:
HTH
#10 |
You could always do a track day!!!! That will improve you cornering skills no end
Wanted: Transponder and advice | Jester666 | Mini-Twins | 0 | 16-02-09 08:58 PM |
KTM buying advice wanted | lukemillar | Bikes - Talk & Issues | 8 | 11-10-08 10:28 PM |
Riding advice | Scoobs | Bikes - Talk & Issues | 24 | 19-03-08 04:30 PM |
advice wanted | crusty | Bikes - Talk & Issues | 29 | 27-01-07 07:38 PM |
Advice wanted please - Lowers | Moriarty | Bodywork | 1 | 20-05-05 10:45 AM |
