Old 30-08-06, 12:05 PM   #1
c_noble
Default How Do I Derestrict My SV
Hey my 2yrs are finally up and its time to derestrict my curvy SV, i know it has the F1 kit in it, which are plates in the carbs, so how easy is it to remove them myself? As i dont wanna wait for a shop to do it. Any help welcome, thanks in advance.
Old 30-08-06, 12:22 PM   #2
TSM
The Sick Man
TSM's Avatar
have a look at
http://forums.sv650.org/viewtopic.ph...ght=derestrict
it will be similer but you dont have to remove the slides, just the carbs and the washer should be easly seen.
ps. if and when you do it can you take a pic of how your washers were fitted and i can update the article.
Old 02-09-06, 07:05 PM   #3
ugp
hey, undo the clips holding the carbs down, (after taking off airbox and other attached ****e), pull carbs upwards evenly, you will see the washers if the f1 kit as you mentioned, take the washers out, then push the carbs back down. You may find it a tad easier doing the front one first, also using a slight smear of wd40 on the rubbers, makes it a tad easier.
I will post pics of mine when I have it apart again.
ben
Old 02-09-06, 10:34 PM   #4
c_noble
Hey Thanks for the help. Managed to do it easy,easier than i thought. Its soooooooo fast now, different beast compared to the reestricted version. Only ridden in the wet so far so can't wait till its dry
going on a track day and want to derestrict from 33bhp and then back again jans1971 Bikes - Talk & Issues 26 26-09-07 02:23 PM
Derestrict 2000 SY model HELP! sv182 SV Talk, Tuning & Tweaking 44 12-02-05 12:00 AM
