Old 03-09-06, 02:18 PM   #1
fizzwheel
fizzwheel's Avatar
Default How much Fork Oil ?
I have done a search but can't find anything relevant.
The fork seals are blown in my SV and I have a nice patch of fork oil on the floor of my garage.
I've ordered new seals ( Dust & Oil ) for both forks. My question is how much fork oil should I be putting into each fork leg ?
I'm 14 1/2 stone ish, Remember the SV is my winter hack so I dont want to be spending mega money on it. I just want to get it back on the road again. So things like GSXR front ends or new springs are not something I am considering doing. I dont want the bike to handle like a GSXR because I already have one of those
Bike is a K1 SVS, 33,000 on the clock. It was reprung by the previous owner but I dont know what springs were fitted.
Thanks
Fizz
Old 03-09-06, 02:30 PM   #2
TSM
The Sick Man
TSM's Avatar
look on the racetech website
Old 03-09-06, 03:10 PM   #3
21QUEST
21QUEST's Avatar
Fizz , a lot of after markek springs have the rates etched on one end of the springs. If not marked on the springs it can be calculated to give you a fairly good idea what you have.
With regards to fork oil if the have been resprung I'll personally run a bit more of an air gap from standard(maybe 5mm to 10mm bigger). Easy enough to add a bit more if the forks using all travel too easily. With higher rated spring you can usaully afford to rund a larger air gap from standard.
10 WT oil should be okay especially with winter coming assumming the the bike wasn't respung for a 400Lbs rider .
If the guy was a similar weight to you probably springs are like .85-.9 depending on preference. I'm about a 180Lbs clothed and for road .8 or .85 does me nicely.
Ben
Nemo me impune lacessit.
Old 03-09-06, 06:17 PM   #4
fizzwheel
fizzwheel's Avatar
Thanks TSM. The ractech website says 130mm of fork oil.
Ben, I was thinking 10WT oil as well. I'm guessing though that any new oil is goign to feel better than it does at the moment. Trouble is I'm spoilt with the GSXR so whatever I do to the bike its still not going to feel like that does hence the reason why I just want to spend as little as possible to get the bike back on the road before they start gritting again.
Also it needs MOT'ing in October and its not going to pass in the state its in at the moment
Old 04-09-06, 10:29 AM   #5
jambo
jambo's Avatar
Just for the record a T reg '99 Curvey "S" has a stock airgap of 104mm, the whole 99-02 range is between 104mm and 102mm, so the 130mm airgap is probably compensating for the stifer springs. Best make sure you've got them or it'll be even more divey
Good luck!
Jambo
Old 04-09-06, 10:31 AM   #6
21QUEST
21QUEST's Avatar
Good luck!
Jambo
Correct
Ben
Old 04-09-06, 10:37 AM   #7
jambo
jambo's Avatar
Originally Posted by 21QUEST
Correct
Ben
Well I just thought I'd throw in the stock Airgap too
Old 04-09-06, 10:40 AM   #8
fizzwheel
fizzwheel's Avatar
OK well I still dont understand.
If I was running the bike on standard springs. How much fork oil should I put in ?
As I dont know what springs I've got in there. Would it make sense to start with the amount of oil for standard springs and then add or remove oil from that point.
This is all a bit new to me
Old 04-09-06, 10:46 AM   #9
chazzyb
Fizz, it's not how much you put in, but the height of the air gap *above* the oil as you fill them, that's important. Reckon on best part of half a litre per leg, but it's the air gap you need to keep your eye on. In case it's not already clear (I'm sure it is) you need to get the forks out of the bike to do this. The forks must be upright, fully compressed with no springs in them to set the air gap.
Old 04-09-06, 10:49 AM   #10
fizzwheel
fizzwheel's Avatar
Oh I see. thats starting to make sense now.
Thanks again
New fork oil. Fuzz SV Talk, Tuning & Tweaking 10 21-01-09 06:22 PM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
How much fork oil do you need and where to buy ?? SpankyHam SV Talk, Tuning & Tweaking 2 14-08-05 08:02 PM
Fork OIL - which one ? SpankyHam SV Talk, Tuning & Tweaking 5 28-07-05 06:42 PM
