Old 04-09-06, 09:54 AM   #1
TSM
The Sick Man
TSM's Avatar
Default Coil mod
I, because i feal like it and also like fiddling have been thinking about changing the coils on the SV to the newer modern coilpack "candlestick" type.
Now anyone done this mod? Whats the possable implications on the SV engine?
I dont expect it to make any diffrence, but if it does then hey people may follow.
If anyone has a standard SV spark plug cap to hand, can you please measure it from base to top. Thanks.
Old 04-09-06, 10:00 AM   #2
svrash
What benefits do you get doing this?
Its 11cm to the angle or 14cm end to end
Old 04-09-06, 12:21 PM   #3
jambo
jambo's Avatar
The rear would be fine, but the top of that cap would be right in the firing line for water off the front wheel. Not sure it would be of any benefit to the bike anyway
That said if you want any measurements off the all-in-one coils let me know as the kwak has them and is due a service in a couple of weeks.
Old 04-09-06, 01:04 PM   #4
TSM
The Sick Man
TSM's Avatar
If ive not done it by then, please give me the size, i think there are diffrent sizes though.
The water getting in the contacts on the front cylinder wont be a problem as i will be soldering wires directly to the pins and then filling the socket up with some epoxy. The plug is not on the SV loom and guessing Suzuki its not possable to buy seperatly.
Old 04-09-06, 01:07 PM   #5
Yeah, that should work. But I'd be surprised if you see a benefit, SV has good burn and spark as standard... Interesting to see how it works out though, never heard of anyone doing it for these before.
Old 04-09-06, 01:10 PM   #6
TSM
The Sick Man
TSM's Avatar
Exactly, its not been done before. People have asked about what mods to coils peeps have done on SVrider but there has never realy been a reply.
I will be saving some weight though on my already lightened bike
Old 04-09-06, 05:22 PM   #7
svrash
About 8oz
Old 04-09-06, 09:25 PM   #8
empty
the ones from a zx6r j1/2 are probably a similar diameter to the SV, certainly you can use an SV plug socket to extract a zx6r spark plug, however I think they might be a bit long. If I've got any time in the next few days when sorting out the fuel pump on the kwak I'll give one a try.
MT
Old 04-09-06, 09:40 PM   #9
valleyboy
They are effing expensive!
£85 each expensive to be exact...
trust me.. I bought a replacement thinking it would solve some problems I had on my Kwak.. turns out it wasnt the stick coils.... but at least I found out how expensive some parts are! though, if you know the right people, you can get them far cheaper than that... I ended up paying £60.. just because the owner of the garage was there and he took pitty on me....
Old 04-09-06, 10:33 PM   #10
TSM
The Sick Man
TSM's Avatar
Thats because you bought new, but SRAD GSXRs have had them and all GSXRs since, you can pickup a set of 4 off ebay for as little as £15.
SV650 Coil Niallers SV Talk, Tuning & Tweaking 5 14-03-08 03:34 PM
CDI & coil hovis Stuff Wanted 4 02-07-07 03:54 PM
Coil Polarity andy SV Talk, Tuning & Tweaking 1 12-06-07 07:02 PM
Lacuna Coil Amanda M Idle Banter 6 14-10-06 01:28 PM
Coil Advice: MrMessy Bikes - Talk & Issues 7 14-08-05 08:34 AM
