Old 05-09-06, 09:16 AM   #1
hovis
Default IT Help - Purchase of new PC
i cant cppe with this libary net it wont let me read anytin........im off to pc world,any advice??
Old 05-09-06, 09:17 AM   #2
Jabba
Default Re: pc
Yeah - don't go!!
Mail order from Mesh or Evesham is the way to go
Old 05-09-06, 09:26 AM   #3
rwoodcock01
Even Dell is better than PC world, but at a pinch if its the best you have.
You could learn to build your own, I have built all my PC's, have yet to buy one.
Good luck!
Rich
Old 05-09-06, 09:34 AM   #4
Baph
As above, don't go to PC World. You'll only pay over the odds & have a 5year warranty that's barely worth the paper it's written on.
If you have to buy from a shop, use a small local one. But also, if you're buying a computer, don't listen to the sales folks, they'll only try to sell you a top spec gaming machine to be used as a typewriter.
At the end of the day, it's about buying something that will suit your requirements, with enough room for expansion later on.
Not everyone needs, or wants, a top spec machine, so if you dont, don't pay the top prices!
Old 05-09-06, 09:36 AM   #5
hovis
Default ?
troble is i dont know a thing about em
Old 05-09-06, 09:40 AM   #6
454697819
Default Re: ?
what do you do with ur comp? and what do you want to do with it?
Old 05-09-06, 09:40 AM   #7
Jabba
Default Re: ?
Basically, go for the fastest processor, biggest hard-drive and most RAM that you can afford.
Get Windows XP Pro is you can.
If all you are planning to do is surf the 'net and send emails that you don't need a top-spec machine.
Old 05-09-06, 09:44 AM   #8
hovis
JUST surf the net, thats all i want to do mabe copy cds & dvds (shhhhhhhhhh).................dell have 1 at £349do ypu have to set it up yourself
Old 05-09-06, 09:47 AM   #9
Mr Toad
what do you want to do with it ?
play games = expensive
surf the internet, send emails , do a bit of word processing & spreadsheet work
= get the cheapest you can find as they're all fast enough these days
something in between if you're going to do lots of image editing, or video encoding (which you'll need to do if copying DVDs)
try and get at least a 17" display, 15" are a bit hard on the eyes after a while
ram - 512MB should be OK
hard disk, 80GB should be plenty to start with
do you want a desktop or laptop - laptops are generally more expensive, but easier if you've got space issues or need move it about
anything else can easily be upgraded/added on once you've got the beastie
Old 05-09-06, 09:50 AM   #10
rwoodcock01
Setting it up is easy, switch in on and away you go, answer the questions it asks you, and you get a decent set of recovery disks!
I would recomend this one as a techy:
http://www1.euro.dell.com/content/pr...hs1&l=en&s=dhs
Its a nice duo core system, its not bad plus leaves you room to expand later, and its not too heavy on the bank balance.
Rich
Help me with this possible purchase? RayRay SV Talk, Tuning & Tweaking 9 31-12-08 07:37 PM
New purchase. ocr_sv SV Talk, Tuning & Tweaking 10 02-05-08 04:10 PM
Help with car purchase? svJvJ Idle Banter 22 28-08-07 09:14 PM
Pak-a-mak purchase Moriarty Helmets 8 17-08-05 11:47 AM
Just another purchase on the cheap - The Mass Bikes - Talk & Issues 1 22-04-05 07:18 PM
