Old 09-09-06, 09:51 PM   #1
catmad
Default phone/gps powering?
i would like to be able to power my phone/gps from the bikes battery
what is the best way to go about this,
Old 09-09-06, 09:59 PM   #2
svrash
I got a cigarette lighter socket under my pillion seat, its has a in line fuse running from a live source on the right hand side of the bike
Old 10-09-06, 03:09 PM   #3
mac608
Where'd you get it from? and what goes to the negative on the lighter socket?
Ta
mac608 is offline   Reply With Quote
Old 10-09-06, 04:13 PM   #4
Kylie
Kylie's Avatar
Me too, I got the socket from a local car parts place, had two crocodile clips on it so you could connect the socket up to a car battery (???) but snip them off and connect to your bike and works just fine.
All that Halfords had was a chav one with built in neon lights
I'm Mike. Kylie is an SK3 with OE lowers, R&G bungs, OE double bubble, Scottoiler, Starcomm, Hamicad tail tidy, bruised and in need of a wash.
Kylie is offline   Reply With Quote
Old 10-09-06, 06:37 PM   #5
jim@55
this kinda thing
http://www.xrv.org.uk/articles/artic...nd_lighter.php
ok its not an sv but theyr all the same kinda
Old 10-09-06, 06:45 PM   #6
chazzyb
Sounds like the one I have. Not a lot of money from memory (round £3 mark?), has its own has inline fuse so you can connect it directly to the battery. This means you can charge your phone without the bike's ignition on.
Old 10-09-06, 07:57 PM   #7
Jussi
I stole the power for gps from the tail light when i switched to led-tail light. it is "behind" a braker and only operates when power / lights are on. That is no problem since in Finland you are supposed to have the lights on 24/7
Jussi
Old 10-09-06, 11:01 PM   #8
svrash
Any motor factors or car shop
Ta
A wire ..............connected to an earth (the frame)
Old 11-09-06, 07:19 AM   #9
mac608
Perhaps what I should have said was does it make any difference which connector on the cig socket holds the earth.
Judging by the instructions here http://www.xrv.org.uk/articles/artic...nd_lighter.php
it doesn't
Old 11-09-06, 08:56 AM   #10
Baph
Funny that this thread should pop up! Being that I've recently offered advice via PM to a few members of the forum!
Personally, I'm the same as you lot, and use a cigarette lighter socket. Made up my own from parts. Probably cost me less than £3. Wired from the live ignition (in parallel to the ignition) so that it only works when the ignition is on.
But then, some folks are posh. After talking to SoulKiss, he has, or will have at least, a USB hub in his bike!
Powering a sat-nav, difference in USB leads?? dyzio Idle Banter 3 19-05-09 03:21 PM
powering tom tom rider russg Bikes - Talk & Issues 5 18-05-09 07:40 PM
Phone Nut DarrenSV650S Idle Banter 3 12-07-08 06:55 PM
I've got me a new phone!!!! Caddy2000 Idle Banter 18 03-10-07 12:38 PM
new phone hovis Idle Banter 2 30-09-06 11:24 AM
