Old 11-09-06, 10:36 AM   #1
lukemillar
Default what solvent and sealant?
When removing the valve/rocker covers, Mr Haynes says
Clean the mating surface of the cylinder head with solvent, removing all traces of old sealant
and then:
Apply the sealant to the cut-outs in the cylinder head where the hasket half-cirlces fit
Apart from quoting the suzuki stuff (Suzuki Bond no. 1207B) they don't go into anymore detail on what the sealant and solvent is.
So:
What are the sealant and solvent as described above more commonly known as
Merci buckets
Luke
Old 11-09-06, 11:02 AM   #2
Viney
I was under the impression that they have a rubber seal, if thats the case, then i wouldnt use a sealent. However, i have never taken them off so dont know for sure.
Old 11-09-06, 11:09 AM   #3
andy
I agree, I have taken them off and no sealant needed
Old 11-09-06, 11:22 AM   #4
lukemillar
The way that Haynes describe it, I think they want you to peel of the rubber gasket, clean off the old sealant, put fresh sealant on, and seat the gasket back into place. I guess from the replies that most people just leave the gasket in place when removing the cover and avoid resealing it.
Old 11-09-06, 11:29 AM   #5
andy
It is a gasket, by definition it does not need sealing unless there is something wrong with it.
Old 11-09-06, 01:16 PM   #6
Pretty sure they have some sort of sealant on from the factory- I remember the drescents being pretty stuck. I just peeled the old muck off and reinstalled dry, worked just fine.
Old 11-09-06, 01:45 PM   #7
svrash
me 6
Old 11-09-06, 04:44 PM   #8
mart
drel magic stuff will hold 5 bar wont really need it though
Gasket Sealant gettin2dizzy Bikes - Talk & Issues 5 21-04-09 07:10 PM
What is a High Flashpoint Solvent 2mths SV Talk, Tuning & Tweaking 23 22-06-07 08:24 AM
where to buy acetone (or other fiberglass resin solvent/cleaner)? weazelz SV Talk, Tuning & Tweaking 6 08-05-07 09:09 AM
Sealant danf1234 SV Talk, Tuning & Tweaking 4 17-02-07 11:54 AM
Solvent for cleaning and soaking carb bits please petevtwin650 SV Talk, Tuning & Tweaking 11 23-05-06 02:42 PM
