Old 12-09-06, 10:08 PM   #1
stuartyboy
Default SV650 Glossary
I've posted this in the Tweaking section but I thought there might be a lot of good stuff from guys who frequent the B-T&I section as well.
Kilted Ginger on the SV Eccosse forum made a very good point that a lot of posts presume we all know the various terms, abreviations and acronyms. Things like "pointy", "curvy" "hero blobs" etc. I certainly wonder what a lot of stuff means.
Anyway to cut a long story short, I've compiled a wee online dtabase at
http://designoverload.co.uk/sv650
If possible - please add as much as of your expertise as you can. If you see an explanation already added then by all means add your own take on it. I can merge them all together.
You can add photos but these will be queued - only to prevent outsiders uploading dodgy crap.
Old 13-09-06, 08:36 AM   #2
Stu
Trinity
Stu's Avatar
I thought Pointy/Curvey was to do with the frame rather than/as well as the body panels?
Old 13-09-06, 01:34 PM   #3
Stu
Trinity
Stu's Avatar
Just found the other pages
ScottOiler - Should refer to the other makes available that do the same job e.g. loobman, Hawk etc.
Tail tidy - Could explain what a snow shovel is and refer to the fact that tail tidy is generally only relevant to the pointy model.
Seat cowl - if it available from Suzuki, is it aftermarket?
Baffle - The stock can comes with a baffle that the US guys on SVrider like to remove by a mufflerectomy. Also I would more describe it as something that is removed to increase sound
Static sag - The amount that the weight of the bike compresses the suspension without any extra weight such as rider,luggage etc
Yokes - Flat piece of metal with 3 holes in it holding the forks. There is a top and a bottom yoke.
My clipons are attached to my forks not my yokes.
BTW what are clipons?
Tuning - TRE = Timing Retard Eliminator
Tyres - You've described 14's as 20's
Old 13-09-06, 05:13 PM   #4
stuartyboy
I didn't write any of these (except the stradas)- all submitted by other people. Instead of posting here why not post on the glossary. Put in a correction if you feel neccessary. Like I say, if it builds it will be useful.
Old 13-09-06, 05:26 PM   #5
Stu
Trinity
Stu's Avatar
Yeah but I was kinda looking for a discussion before they get posted up as half of my points were questions.
Unless the Database could be edited by all in a Wiki style?
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
Glossary of terms stuartyboy SV Talk, Tuning & Tweaking 21 16-09-06 07:09 AM
The NHS and the front bottom glossary Razor Idle Banter 22 13-07-06 10:30 PM
