Old 15-09-06, 04:47 PM   #1
Warren
Default calling all electricians, or anything close.
electricians.
i fitted in a dimmer light switch into my bedroom a few weeks ago, was simple enough wiring it up, and it works
however, now when its dimmed, the switch gives you an electric shock,
not like a painful one, just like you can feel the current flowing through it and it tingles a bit.
the case shouldnt be live anyway, so i double checked it was earthed ok. and it is. but its still giving you a buzz.
how can i find out where the problem lies ?
Old 15-09-06, 05:51 PM   #2
amnesia
If its only when the switch is dimmed I would suspect it was faulty - providing the wiring IS correct and hasn't come loose.
Check the wiring first - then check it again.
Old 15-09-06, 06:05 PM   #3
Warren
ok cheers mate, i take it there is no point trying to fix the dimmer unit ?
if its earthed, how come i can feel the buzzing when its on dim ?
i was hoping to have a play with the mulitmeter, ive got one, but havent a clue how to use it.
Old 15-09-06, 06:15 PM   #4
Beenz
Anorak alert
If you feel a physical vibration when touching the switch as opposed to a shock but can hear a quiet buzzing, I guess its the switch thats doing it (loose triac heatsink). Some dimmers dim by switching the current on and off very fast and not by reducing the voltage.
Anorak alert over :P
Old 15-09-06, 06:18 PM   #5
Warren
Originally Posted by Beenz
Anorak alert
ok, i sort of understand,
can i have the "for dummies" version please?
Old 15-09-06, 06:49 PM   #6
Beenz
Anorak alert
Yup, I'll try.
If it feels like a electrical shock however mild, switch off the breaker and take the dimmer and bin it. There's a lot of cheap stuff about and if its using mains electricity 230- 240V AC this stuff can do a lot of harm. If in any doubt at all I'd get rid of it. Shocks and fire are just not woth it.
I'm sorry for being blunt but no one can turn back the clock after something simple like a faulty switch ends in catastrophic results.
Sorry I should have said that the first time.
Old 15-09-06, 09:30 PM   #7
Stingo
Stingo's Avatar
Have you still got the receipt for the switch? Take it back to the shop...now. If it was from B&Q or similar major retailer, they'll probably take it back without a receipt.
Ditto what Beenz said - major safety issue - if in doubt, get rid!!
HTH.
Twitter: @poseidon_ashore
Old 15-09-06, 10:10 PM   #8
the_runt69
Just put a "saver" bulb in the bedroom and that buzzes and makes funny noises when turned on with the dimmer switch and fiickers when not up to full power. Normal bulbs are OK tho
H
Old 15-09-06, 10:15 PM   #9
Razor
Measure between the part you're touching and earth. A cheap multi meter is an essential tool.
Old 15-09-06, 10:20 PM   #10
CheekyLemon
Saver bulbs don't work with Dimmers. As far as I know any way.
If it's the same bulbs I'm thinking of....
Paging the auto-electricians Lozzo SV Talk, Tuning & Tweaking 15 19-02-08 02:43 PM
That was close!! Blue_SV650S Bikes - Talk & Issues 17 03-12-07 06:12 PM
How close ??!! Supervox Idle Banter 1 16-10-07 04:00 PM
calling all geeks(in the nicest name calling way) jim@55 Idle Banter 11 25-06-07 08:55 AM
Any electricians furrybean Idle Banter 9 12-11-06 03:47 PM
