Old 20-09-06, 08:02 PM   #1
weazelz
Default racetech emulators
having got the back end of my bike nicely sorted with a zx10r shock, I've just ordered myself a set of racetech cartidge emulators
any gotcha's I should know about before fitting these babies?
I have a curvy with preload adjusters, hyperpro progressive springs & 15W oil in the front at the moment btw
Old 20-09-06, 08:43 PM   #2
r4ce_e3nd
maybee this is worth reading (from American SV forum) and especialy the part of the damper rod modification:
http://www.socalsvriders.org/forums/...665#post260665
I did it the Zoran way and it feels very good en solid...
Old 21-09-06, 07:49 AM   #3
lukemillar
Buy some new copper crush washers for the damping rod bolts now, rather than finding out halfway through the job that you need them!
Old 21-09-06, 09:40 AM   #4
Blue_SV650S
Default Re: racetech emulators
I thought emulators and progressive springs were a no no? Might be worth considering some linier springs?
Old 21-09-06, 10:21 AM   #5
Flamin_Squirrel
Yes I think that's right.
From what I understand, progressive springs are used to try and overcome the short falls of damping rods. Emulators solve this problem, so linear springs should be used.
Old 21-09-06, 03:24 PM   #6
weazelz
thanks for the replies & suggestions, I do have some linear '+10%' springs that the bike came with, I may put them back in. I may have to make up a new spacer tube though - anyone know where I can get the correct sized pipe?
the emulators turned up today - next day from pdq, so I'm suitably impressed with them (again). the installation seems to be fairly straightforward, but I'm not 100% clear what the preload adjuster controls - is this for compression or rebound damping?
Old 21-09-06, 04:01 PM   #7
Blue_SV650S
I'll measure the tube when I get home for you. The preload (on emulator) is for compression. I have mine at 1.5 turns from the point where the slack is just taken up on the spring and 15w oil and I am happy with the results.
Old 21-09-06, 04:02 PM   #8
sdusk
weazelz, the emulator preload spring controls the compression damping. The oil weight primarily controls the rebound damping, but will also have a lesser effect on the compression damping. I use 20w oil and 1.5 turns of emulator spring preload. I initially tried 15w oil and 2 turns of emulator spring preload but this resulted in too much imbalance between compression and rebound damping for me.
Old 21-09-06, 07:41 PM   #9
Blue_SV650S
OD of tube is 32mm
Old 22-09-06, 08:02 PM   #10
weazelz
right, I've done some measuring & here's what I've got:
* progressive springs & adjustable preload caps:
450mm spring (uncompressed)
60mm spacer
14-32mm adjustable cap (min-max)
2mm cap disk
526-544mm total
* linear springs & non-adjustable preload caps:
328mm spring (uncompressed)
198mm spacer
1mm washer
0mm non-adjustable cap
527mm total
does anyone know the length of standard springs & spacers?
what I want to do is give the progressives to my friend with an '00ish (no preload adjust) curvy & run the linears in mine with the racetechs & prelaod adjusters. can I make the required spacers from the existing spacers or do I need to source some 32mm tubing?
ta
~a
Racetech Emulators for 99 - 02 curvy (brand new) charlie13 For Sale - SV's and SV related items 15 13-03-09 05:50 PM
Racetech emulators - what fork oil? skov SV Talk, Tuning & Tweaking 0 27-05-08 10:36 AM
Racetech emulators natcar SV Talk, Tuning & Tweaking 58 31-10-07 12:36 PM
Racetech emulators ajbuchardt SV Talk, Tuning & Tweaking 1 12-08-05 05:32 PM
Racetech Emulators and springs pjsv650s Ancillaries 3 30-07-05 12:58 AM
